wobble
Old Jun 5, 2009 | 02:23 AM
badwiser's Avatar
badwiser
Default wobble
I have a 06 low rider with just over 2000 miles. i get a crazy wobble mostly at low speeds when i hit a crack or grove along the road. checked spokes and all seem good and tight.
Any one have any ideas what i should check or is this normal?
Old Jun 5, 2009 | 03:12 AM
CaptGoodvibes's Avatar
CaptGoodvibes
Not sure about the cause of you particular wobble. Did you check to see if the tire is balanced correctly?
I think you need to get out more though. 2000 miles is nothing. Are you the original owner?
Old Jun 5, 2009 | 03:26 AM
maddghost's Avatar
maddghost
I would check tire pressure,very important especially if you don't take it out often.It should be checked once a week!
Old Jun 5, 2009 | 08:40 AM
archergodwin's Avatar
archergodwin
What speed is "low speed"?
Old Jun 5, 2009 | 09:43 AM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Low tire pressure could make the bike just not feel right and move kinda of sluggishly from side to side. The narrow tire up will amplify some road imperfections, I hate to say it but at times that the nature of the beast.
Old Jun 5, 2009 | 09:47 AM
ratt196635's Avatar
ratt196635
I had a slow speed wobble and my front end was loose did the fall away check and tightened it to specs and wobble went away
Old Jun 5, 2009 | 09:55 AM
super05's Avatar
super05
whatever the problem - the stock tire is not helping. the continuous center groove in the factory tires will track a crack or groove in the road. as mentioned - easy fall away or low tire pressure will make this even worse.
Old Jun 5, 2009 | 09:58 AM
LeavenworthJeff's Avatar
LeavenworthJeff
Check out everyone's suggestions above. I was thinking the stock Dunlops have a center groove that will follow cracks and grooves. One reason when it came to a tire change I went with another brand that got rid of that center groove in the tire.
Jeff
Old Jun 5, 2009 | 09:59 AM
LeavenworthJeff
Hey Super05 you beat me to it!
Jeff
Old Aug 1, 2009 | 08:28 PM
big block's Avatar
big block
Call me what you will but ,What is fall away?
Big Block
