Ghost brackets
Old Jun 8, 2009 | 07:31 PM
dwg1956's Avatar
dwg1956
Default Ghost brackets
Has anyone installed Ghost brackets on a Wide Glide and if so where and how did you relocate rear turn signals.
Old Jun 8, 2009 | 08:28 PM
maddoggreene's Avatar
maddoggreene
Used HD's rear turn signal relocation kit. Sorry can't remember the part #.
Old Jun 8, 2009 | 08:31 PM
archergodwin's Avatar
archergodwin
Well, I don't have a wide glide, and I don't have ghost brackets..... but if it helps, I have a FXDC with easy brackets. I'm thinking a lot of similarity there. I bought the cheesy HD single plain jane bar turn signal relocation kit, and mounted the sigs back on the fender. Works till I figure out what exactly I want to do with the rear.....
Old Jun 8, 2009 | 08:52 PM
SC-Longhair's Avatar
SC-Longhair
why do you need to relocate ts?? our ts mount in different hole compared to the fender bolts.
Old Jun 8, 2009 | 09:07 PM
SuperFastGlide's Avatar
SuperFastGlide
turn signal "is" the rear fender bolt, theres only 2 bolts on a dyna strut not counting the shock
Old Jun 8, 2009 | 09:08 PM
SC-Longhair
not true i have two fender bolts and where my ts mount on my wg like the op..
notice ts...and two fender bolts. that is a stock wg setup
Old Jun 11, 2009 | 11:57 PM
trapper_canada's Avatar
trapper_canada
I bought BareBacks (LOVE THEM) for my '08 Wide Glide. Using some OEM Harley Bags. No turn signal relocation required. Unless you have monster bags...you should be fine without moving the turn signals. From what I understand the moving of the signals is not required on the FXDWG.
Old Jun 12, 2009 | 08:53 AM
rounder's Avatar
rounder
wide glide/ fatbob strut different for the different fender.
Old Jun 12, 2009 | 09:07 AM
SC-Longhair
Looks like the OP's '03 is setup just a bit different. His TS is behind the rear fender bolt, so TS relocation would be necessary. I checked his album.
On late model WG's, the turn signals are at the very rear of the strut so they don't interfere with the fender bolts.
Could you just move the turn signals to the very rear of the strut cover? Maybe modify the mount just a bit, and tuck it in as far as possible.
valhalla84
Dyna Parts
Jun 26, 2014 08:00 AM
drive805
Mar 27, 2014 12:27 AM
DGlide04
Sep 23, 2010 05:12 PM
rob_will
Nov 3, 2007 03:07 AM
cajun883custom
Mar 18, 2007 12:40 AM
