stainless fuel crossover
Old Jun 19, 2009 | 09:54 PM
1plumr1's Avatar
1plumr1
I covered the black rubber one with chrome wire loom and think it looks good. At least it doesn't leak.
fjm3rd's Avatar
fjm3rd
Well I guess I have to say I have one also. And when I put it on I got one side tight but the other side the rubber squeezed out and leaked all over the place until I took it off and just zip tied the original rubber hose back on. I got more rubber seals but haven't installed it yet. I'm thinking the tank has to be drained totally with no chance of gas getting on the rubber seals because that lubes them and lets them squeeze out of the nut. I'll try it sometime when I'm low on gas and take the time to drain it completely
Old Jun 20, 2009 | 12:42 AM
Prodriverdon's Avatar
Prodriverdon
Mine was bought aftermarket and I think I have an extra one you can have for the cost of shipping. It was never used. If interested I will go out and measure it for you. Mine doesnt leak and it has been on for 3 years. P/M me.
Old Jun 20, 2009 | 07:23 AM
Naz_Man's Avatar
Naz_Man
This works and looks Great!!
Old Jun 20, 2009 | 07:31 AM
SC-Longhair's Avatar
SC-Longhair
Originally Posted by Baeseman1
It didn't fit with a tank lift.
Was that a 2" or 3" lift? With a 2", the crossover should fit because you don't modify it at all. The 3" lift (I have), you definitely need a longer crossover.
I've been contemplating assembling my own using a compression fitting. You can get stainless tubing, cut it to fit and wa-la.
Old Jun 21, 2009 | 04:26 PM
Prodriverdon
Oh Canada!!!!!!!!
Old Jun 21, 2009 | 07:55 PM
2NAHNTR's Avatar
2NAHNTR
I tried to put one on and it leaked. If you want it, I will send it to you for the shipping costs - $5.
Old Jun 21, 2009 | 08:27 PM
8541hog's Avatar
8541hog
Vic
If you decide to make one up, be sure to get the quick-disconnect fittings, should you ever need to remove the tank, no need to drain it to remove the crossover. I added these with braided fuel line a couple months ago. I used the line Naz-Man linked to above from JP. and no leakage issues at all. dpriest posted a link a while back check it out for more info.
https://www.hdforums.com/forum/4671599-post2.html
Old Jun 22, 2009 | 07:44 AM
SC-Longhair
That's what that fitting from ebay is, quick disconnect. Per the auction, both sides of it are valved so it shouldn't leak when separated.
Old Jun 22, 2009 | 09:43 AM
Airborne350G's Avatar
Airborne350G
I got one that you posted from ebay.. Not sure if it is the same one. I like the metal chrome ones better then the plastic ones. Now to find time to change it out. LOL
