tire changes
Old Jun 24, 2009 | 10:35 PM
Centerline's Avatar
Centerline
I change my own tires and I normally change them when they have each reached their wear limits.
Old Jun 24, 2009 | 11:28 PM
fixxr's Avatar
fixxr
+1 on that! I dont throw money away,Damn tires cost to much now!
Old Jun 25, 2009 | 06:47 AM
man4mopar's Avatar
man4mopar
Originally Posted by archergodwin
New tube with new tire.... you can't tell wear and fatigue on a tube by looking at it.
Can't always find the flaw in the new tube either. Fact is a new tube is no safer then using a well checked used tube.And one should always check out a new tube as well before install. But if you feel safer by all means change them.
Ways to check tube status is to air it up slightly larger then tire. Checking for cracks, thin spots and rub wear etc. Dunking it underwater will find any leaks. Checking it deflated will not find much.
Old Jun 25, 2009 | 09:13 AM
jimsflh's Avatar
jimsflh
I think you should blow it up until ½ lb of pressure before it pops, this may take several tries to get it right, but hey, you're worth it right!?!
LOL, just kidding, I agree, check the tubes as TheMoparMeister says, old or new before mounting.
Old Jun 25, 2009 | 10:11 AM
rayfinseats's Avatar
rayfinseats
It has always been a standing recomendation that if you change one tire, to change the other at the same time. How many out there actually do that? Also, do you really need to put in a new tube every time you change tires.
WHY ???
Stamant59
Aug 3, 2017 11:12 AM
a10182
Nov 20, 2011 08:45 PM
Fatboy Brian
Apr 4, 2010 07:34 AM
cirhere2
Aug 15, 2009 09:04 AM
st john
Jun 19, 2007 01:56 PM
