Screamin Eagle Air Kit Help Please
Old Jun 23, 2009 | 08:11 PM
smjul90's Avatar
smjul90
Default Screamin Eagle Air Kit Help Please
08 Super Glide Custom, I have a new Screamin Eagle air kit and no install direction. Can anyone help me out with a step by step install or mybe post some direction. Looks like it will be simple to install but just want to get it right. I have searched all over and can't find any direction. Thanks to anyone who can help..
Old Jun 23, 2009 | 09:30 PM
sigmoid's Avatar
sigmoid
Which SE kit do you have? The one I put on my '08 is for older versions but should be the same. I can fax you the install sheet if you have a number. Pretty straightforward really; remove the old cover, filter, breathers, backing plate (unclip the induction module from the backing plate 1st, it's a European pollution thing that hooks to nothing, just under a clip) Remove the gasket from the throttle body, clean it up if required, then put the new parts on in reverse order. New gasket, backing plate, glue on the clip for the induction thingy, clip it in, filter mounting studs (60 in/lbs.) breather screws (144 in/lbs) filter, cover.You reuse some of the fasteners and the breathers and air cleaner mounting studs (at least on mine, use new parts if they came with yours) Make sure the o-rings get installed in the backing plate before you put the breathers in. Use blue loctite on the fasteners and breather threads. The rubber plugs fit into the breathers. Tighteen carefully and evenly and don't over tighten the cover. The backing plate is soft aluminum and can warp causing a leak.
Old Jun 23, 2009 | 09:54 PM
smjul90's Avatar
smjul90
Thanks for your help the kit I have is (Screamin' EagleŽ Dyna Stage I Air Cleaner Kit, 29406-08)
Old Jun 24, 2009 | 02:12 PM
sigmoid's Avatar
sigmoid
Here is a link to a zip file of the instructions. You need to sign up at the HD Talking forum to access it. http://www.hdtalking.com/engine_fuel...tructions.html
Old Jun 24, 2009 | 03:10 PM
sigmoid's Avatar
sigmoid
Oops, that one was for touring models. Try this link instead: http://www.box.net/shared/p1zif2sgk8
Old Jun 25, 2009 | 10:44 AM
trapper_canada's Avatar
trapper_canada
I have a pdf here of the instructions I can email you.
oldbikenut
Apr 13, 2015 05:23 PM
Ky-Guy
Sportster Parts
Sep 12, 2013 08:40 PM
Hoblick
Touring Parts
Sep 27, 2011 04:45 AM
stevevfd
Sep 6, 2008 01:57 PM
brock161
Exhaust System Topics
Mar 13, 2007 07:05 PM
