lighting issues
Old Jun 30, 2009 | 04:33 PM
Dutch550's Avatar
Dutch550
Default lighting issues
My 2008 Fat Bob tail light is not working. All the other lights up front are working. This is the only running light out. I checked fuses and changed the bulb. There is only one fuse for the lights and they checked out fine. My brake light works fine as well. I just want to see what any of you recomend to troubleshoot. Has anyone else had this problem with there Fat Bob?
Old Jun 30, 2009 | 06:48 PM
fatboyoz's Avatar
fatboyoz
Check your connections. One under the seat and one behind the light lens. Disconnect them, clean them with electrical cleaner, apply some electrical grease and reassemble. If this does not work, you will have to start chasing the fault with a multimeter to find out where the power supply stops.
Good luck,
Colin.
Old Jul 2, 2009 | 08:09 PM
mmient's Avatar
mmient
Hopefully it's something simple. I had my FXDL at the dealer this morning with the low beam out. High beam and all other lights checked out. They found a wire broken in 2 places in the backbone. Glad it's still under warranty!
Old Jul 9, 2009 | 08:43 PM
Dutch550's Avatar
Dutch550
I have checked all connections that run to the tail light everything seems to be tight. Nothing was loose, even checked under the seat. I need to pick up a multimeter I dont have one. I wonder if botoming out on the bike has caused me to wear out or break one of the wires? let me know if anyone else has advice.
Old Jul 9, 2009 | 09:13 PM
red devil's Avatar
red devil
If you bottomed out, I would check the wiring under the fender to see if the tire wore through the insulation.
izhd
Aug 20, 2014 07:39 PM
tach13
Dec 19, 2012 07:24 PM
schulze
Apr 5, 2012 03:57 PM
JFonzka
Apr 24, 2008 06:46 PM
zenwarrior
Custom Models
May 9, 2006 12:05 AM
