T-bars internal wiring?
Old Jul 3, 2009 | 09:45 PM
JoeGrapes's Avatar
JoeGrapes
Default T-bars internal wiring?
What is the best way to run the wires thru the T-bars? Pull the wires out of the frame and take the plugs off? Disconect the wires from at the the front? Cutting the wires and replice them together?
Old Jul 3, 2009 | 10:11 PM
RCB's Avatar
RCB
Disconnect the wires from the connector. Do 1 side of the connector at a time and make a drawing showing where each wire goes back. This is better than cutting and splicing which could come back and haunt you later on down the road. Fish a scrap piece of wire through the bars first to use for pulling your harness through the bars. Spray some WD40 to help pulling harness through. Good Luck.
Old Jul 4, 2009 | 12:38 AM
sgt.tackleberry45's Avatar
sgt.tackleberry45
i just did it with mine. i cut them at the frame neck, soldered them back together and used shrink wrap wire covers. and i used a little silicone caulk dabs at the ends of the shrink wrap for extra safety. if you do it that way... stagger you spots where you connect the wires, so that you dont end up with a huge bulge that wont fit in the shrink wrap
medicmouse
Electrical/Lighting/Alarm
Aug 2, 2017 09:46 AM
TylerBoehm
Jun 11, 2014 02:14 AM
stl jeanes
May 26, 2013 02:56 PM
jmaxx24
Dec 8, 2012 05:55 PM
georgiabiker
Mar 19, 2008 06:57 PM
