Look at these sparke plug wires
Old Jul 6, 2009 | 06:45 PM
PG13125's Avatar
PG13125
Default Look at these sparke plug wires
Hi guys,
I just received and installed my new plug wire, RED, to be a part of the "red club" , but i order from http://uskoolines.com.
Very good looking product.
Attached Thumbnails Look at these sparke plug wires-img_4764.jpg   Look at these sparke plug wires-img_4766.jpg
Old Jul 6, 2009 | 06:52 PM
'09fxdb's Avatar
'09fxdb
WOW....talk about a mod you can do yourself.....
Old Jul 6, 2009 | 07:02 PM
airvette's Avatar
airvette
Default Spark plug wires
Make sure your wires don't rub on the fuel line. I found my stock wire worn where it touched the line. I separated them with a nylon tie wrap - problem solved.
Old Jul 6, 2009 | 07:16 PM
ZeroFiveFour's Avatar
ZeroFiveFour
Looks good!
If you want to avoid all contact with your fuel line you can attach a small clip to the horn bolt and run your wire thru it. I used and old brake line clip that I had left over afer installing my new cables. All I had to do was ream the hole of the clip" a bit with a cordless drill. It took about 2 minutes. See photo.
Cheers,
Tom
Old Jul 6, 2009 | 07:23 PM
JaronB's Avatar
JaronB
It matches your rear reflectors!!
Old Jul 6, 2009 | 07:52 PM
PG13125's Avatar
PG13125
quote = ZEROFIVEFOUR
Looks good!
Cheers,
Tom
THANKS TOM, I LIKE THE IDEA
PS: JaronB, rear reflectors should be gone tomorrow (lol)
Old Jul 6, 2009 | 08:55 PM
archergodwin's Avatar
archergodwin
I'll be interested in knowing if those wires cause your ECM to throw any codes. Not saying they will, but there is enough "disinformation" floating around out there...
Who makes them, and were they a direct model application?
Old Jul 6, 2009 | 09:10 PM
JaronB's Avatar
JaronB
That's what I'm talking about!! I'll be getting red wires too eventually! I like em!
Old Jul 6, 2009 | 09:17 PM
Failz's Avatar
Failz
A simple mod that can look pretty cool
Old Jul 6, 2009 | 09:21 PM
WingNut55's Avatar
WingNut55
If you bring it to my Shop or most any shop, I will not Dyno Tune the bike with out the factory wires and plugs ... Wont throw a code ..
