Fork seals FXDL
Old Jul 7, 2009 | 09:58 AM
Max10's Avatar
Max10
Default Fork seals FXDL
Bought a 2008 Low Rider last year. From day one there seemed to be an oil leak from both sides of forks. Even after about 10 miles there would be a ring around the forks at the point of highest compression. A light smear of oil from there on down. Took it to the dealer. They said there wasn't any oil on the top of sealer cups so they said this was normal. I know it's not normal. Never seen this on my other bikes. Does seem odd that both leak equally. They look exactly the same after a ride. Maybe one would be bad, but both? Dealers probably trying to get out of a warranty repair. Anybody else have this problem? Thanks.
Old Jul 7, 2009 | 05:45 PM
jmpancoast's Avatar
jmpancoast
Dealers make good money on a legitimate warranty repair.
I believe what you are experiencing is normal as a thin layer is acceptable. If it runs, you can push the remains to a puddle with your finger, or it pools on top of the seals, then you have a leakage.
Just an opinion.
23Seven
Jan 2, 2017 09:46 PM
toku58
Jun 8, 2015 08:17 PM
sire86
Oct 6, 2013 01:40 PM
Charlie Fogg
Sep 22, 2013 07:58 PM
Max10
Jul 11, 2010 11:21 AM
