Tranny leaking - O-ring shot - questions
Old Jul 8, 2009 | 03:43 PM
rbabos's Avatar
rbabos
Oil the oring before tightening. this prevents it from rolling into a ball and tearing up, as in your case. You cannot overtighten the oring. It fits into a counterbore and compresses in there to seal. The plug bottoms out to metal to metal to control this. You can however strip threads with overtightening. Once in a great while I even tear one, but it will always show problems with bulging out or with a piece hanging down. Always check visually before adding oil. Lot easier to replace if needed that way.
Ron
Old Jul 8, 2009 | 03:46 PM
maddghost's Avatar
maddghost
If you drain your oil into a clean receptacle why not re-use it? of course you can. HD doesn't even recomend changing that often as there is no ignition involved with the tranny. The o-ring is 99 cents.And the torque value is 14 to 21 ft lbs, but HD only barely tightens them like 2 ft lbs. Weird huh?I've noticed HD teks put high heat threadlock on there too! that's just to cover their ****.
Old Jul 8, 2009 | 03:47 PM
xbox's Avatar
xbox
Tranny Leaking..... and O-Ring shot.....
Sounds soo Wrong.....
Old Jul 8, 2009 | 04:07 PM
2007fxdc's Avatar
2007fxdc
I hear you guys on re-using the fluid or saving what I can by plugging the hole quickly. But, I've lost some fluid and will lose more and so I'll have to go buy a quart anyway. Not gonna save me anything really to re-use what's in there.
I think I'm all set if somebody can tell me what size that o-ring is...
Old Jul 8, 2009 | 04:10 PM
maddghost's Avatar
maddghost
HD has the exact o-rings just get a bag full for future needs.My last oil changa I did two rings the third was fine.
Old Jul 8, 2009 | 06:38 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
+1 on replacing the O rings and I go one step further, I apply just a little bit of pipe thread sealant on the threads, about 2-3 threads from the magnetic tip. Got it from NAPA about about 7 years ago, that's how much you use.
Old Jul 8, 2009 | 07:52 PM
2007fxdc's Avatar
2007fxdc
I have no problem buying the o-rings from HD but there is no dealer in town to get them from. I hate to drive 2 hours round trip for a 99 cent o-ring or even a bag of them. Maybe I can call my indy and he can tell me what size they are so I can go to the hardware store and pick some up.
Old Jul 12, 2009 | 07:35 AM
Mr. Lucky's Avatar
Mr. Lucky
Dunno if you have already resolved this, but the o-ring size you need is #41. I bought a package of 10 yesterday at Home Depot for $1.97.
Old Jul 12, 2009 | 08:50 AM
WS6 Formula's Avatar
WS6 Formula
My O-rings are long gone, I just use the below thread sealant:
http://www.permatex.com/products/Aut...d_sealants.htm
PermatexŽ Thread Sealant with PTFE
Economical general-purpose fitting sealant. Outperforms tapes and pipe dopes. Seals and resists pressure in air, oil, diesel fuel and hydraulic systems. Remains pliable at higher and lower temperatures. Temperature range -65°F to 300°F (-54°C to 149°C); resists common shop fluids.
Suggested Applications:
Air conditioning fittings, temperature sending fittings
Old Jul 12, 2009 | 09:02 AM
rbabos's Avatar
rbabos
That's the way to do it. Buying these from the dealer is rediculous. I get mine from an auto parts store, handfull at a time for peanuts.
Ron
