New owner questions=Street Bob
Old Jul 15, 2009 | 01:20 PM
MDStbob's Avatar
MDStbob
Default New owner questions=Street Bob
Sorry to bother with simple questions. I just got it this morning How tall a set of apes and on the street bobs with stock cables? I got approval from the boss on a set of slip ons from the wife, what is evryone running.
I tried to do the search and could not find anything.
Jim
Old Jul 15, 2009 | 01:43 PM
vandykemc's Avatar
vandykemc
If I remember right they are 12". I went to 16" Apes and enjoy the ride. I also run SE A/C stage 1 kit, Vance & Hines Fuel Pak, and Vance and Hines Big Shot Staggerds pipes. I really noticed the diffrence from stock when I went with all this.
Old Jul 15, 2009 | 01:45 PM
Redbeard's Avatar
Redbeard
The stock bars are 10s and you can go to 12s without changes. Some have gone to 14s and just tweaked a few things, but not all bars are true to size.
Old Jul 15, 2009 | 01:54 PM
bberck's Avatar
bberck
You can usually go up 2 to 4 inches with the stock cables. Alot will also depend on how wide they are, if they are also wider than stock you may not be able to go up as much. The brake line is uauslly the first to be to short.
Old Jul 15, 2009 | 01:56 PM
DSnoopy's Avatar
DSnoopy
I simply rolled my bars forward a bit and got a similar effect of larger apes and more comfort.
I also run SE A/C stage 1 kit, Vance & Hines Fuel Pak, and Vance and Hines Big Shot Staggerds pipes. Makes a big difference in performance.
Old Jul 15, 2009 | 02:06 PM
shimmon's Avatar
shimmon
rush slip ons sound good... but you will be happier with a full set of pipes, tuner, and high flow air cleaner.
as for apes... you can go up 2" or so safely without modification. any higher you will need longer cables, wires, and brakes lines. unless you do some rerouting of cables and bending of brake lines...
Old Jul 15, 2009 | 02:49 PM
MDStbob's Avatar
MDStbob
Default thanks
I really want the full pipes and fuel mangement but money is tight right now. Thanks for the help.
Jim
Old Jul 15, 2009 | 03:09 PM
DSnoopy's Avatar
DSnoopy
Jim
Just my .02, but you may want to wait. No reason to spend money that isn;t what you want in the end.
Old Jul 15, 2009 | 03:15 PM
maddghost's Avatar
maddghost
Yuor cheapest way to go is a set of bct baffles from what i've heard they replace your stock baffles and for 100$ or so you have a super sound!
Old Jul 15, 2009 | 05:11 PM
Psycotech's Avatar
Psycotech
6th Gear
Jim:
The only slip on pipes authorized by HD that you can put directly on your bike without having them dynoed are the RUSH slip ons. I had the same prob. as you, not enough money, so I put the RUSH black slip ons, on with the 2" baffels and they sound great.
Greg
