fxdx gas tank
Old Jul 16, 2009 | 11:40 PM
ponts's Avatar
ponts
Stage II
Default fxdx gas tank
I'm trying to find an fxdx gas tank for an '02. Will an '05 tank fit on an '02? Are most fxdx tanks interchangeable?
Part number 12496-11 61267-97
thanks
Old Jul 17, 2009 | 02:06 AM
sharkey's Avatar
sharkey
I put an '04 tank on my '01; had to drill and tap a hole in the top of the frame for the back mounting bolt. The "suffix" (ie: 12345-"79") on the HD pn is the year that part was introduced; the example part was first used in 1979.....
Old Jul 17, 2009 | 02:19 AM
RKKY's Avatar
RKKY
Just picked up a Tank for a 2000 FXD I am rebuilding. For an exact fit you need a 97-03. You can make others fit with some modifications. Bit of a PITA to find outside of a dealer since that tank only fits 2 models. If you needed a Wide Glide tank, you can find hundreds.
Old Jul 17, 2009 | 11:05 PM
ponts's Avatar
ponts
Stage II
thanks for the help!
nightstermass
Feb 1, 2015 09:32 PM
05hdultra
Mar 15, 2014 09:09 PM
Sad King Billy
Apr 13, 2012 08:49 PM
jojobrit
Nov 4, 2007 07:50 AM
k2rmx.rob
Dec 16, 2005 02:32 AM
