HD Oil cooler install FYI
Old May 26, 2006 | 06:43 PM
but Ill try 2 try's Avatar
but Ill try 2 try
Default RE: HD Oil cooler install FYI
I read that same book, at least that part of it. I think it's important to remember that no matter how much of a die hard fan you are or how superior and perfect you might think your harley is, you gotta remember it has shortcomings. Why not help it be all that it can be.
Old May 27, 2006 | 06:20 AM
Pippeis's Avatar
Pippeis
ORIGINAL: but Ill try 2 try
Ready to see if those oil temps drop
Not easy to know if it works without any temp indicator an '06 dynas...
ciao...
F
Old May 28, 2006 | 09:58 PM
WildBill76's Avatar
WildBill76
An infrared gun helps. My Dyna ran a lot cooler. Granted it was only a 90 degree day @ 76% humidity. I also put a temporary oil pressure gauge on. I had done the same before I installed the cooler. Oil pressure was up by 14 PSI after the oil cooler installation , and a 80 mile highway run followed by 5 miles of slow traffic. The hotter your oil the lower your oil pressure. I am convincedthe oil cooler is worth every penny. I did not rubber tape my hoses, but after 800 miles of oil cooler service, I have not seen any hose wear or frame paint scuffing. If Ido I will rubber tape mine .
Old May 29, 2006 | 12:30 PM
kiltiemon's Avatar
kiltiemon
Pippeis...
Since we're talkin' "Air Coolers" here... Please fill in the blanks: 9_ _!!!
My comment to one of my "advisor's" when trying to understand the complexity of motorcycles was: "Oh... so it's really just 1/2 of a VW with an "S" Cam!!!... OK! I can deal with that!
Jim aka kiltiemon aka Jim 1987 944S (It was a real toss-up twixt the WideGlide and a V-Rod (hard to resist two water-boilers in the garage!!!))[&:]
JimGnitecki
Engine Mechanical Topics
21
Apr 2, 2014 01:37 PM
pauletich
Jul 23, 2010 01:43 PM
frenchbiker
Jul 16, 2009 08:53 AM
Comfortably Numb
Nov 11, 2007 09:01 PM
VBFTuc
Aug 14, 2007 12:20 AM
