Clutch adjustment
Old Jul 31, 2009 | 01:36 PM
shimmon's Avatar
shimmon
glad you got her fixed up... i finished installing my rocker boxes last night and just i a fired it up and about to test ride it... downpour!!!
Old Jul 31, 2009 | 04:19 PM
rounder's Avatar
rounder
Originally Posted by shimmon
got a question while we are on the subject... my clutch starts to grab well beyond an inch from the bar... if i wanted to make my clutch engage sooner, what needs adjusted??? it feels to me that i should have more room between when the clutch starts to engage and when the clutch is fully engaged.
i've only adjusted my clutch once by the book. so i dont have much to compair my one adjustment too...
loosen the cable adjustment in 1/4 turn increments or less. then check for engagement. Once it is where you want it, tighten the adjuster up.
Old Jul 31, 2009 | 04:22 PM
rounder's Avatar
rounder
Originally Posted by nhfxdb
my street bob surges in the same RPM range in every gear,i was thinking maybe it was the clutch,i have the 07 dyna manual, and followed the procedure for adjusting the clutch, got on it started it put it in gear and the clutch didnt even engage, went nowhere, did it again by the book and even came on here and watched the video for doing the adjustment still nothing, had to back the adjuster screw out 3 1/2 turns to make it work, the manual and video said only 1/2 to 1 turn
adjust the allen bolt in till it lightly seats.That means it just starts to resist your turning it. Also before turning it in turn it out a few turns then turn it back.
Old Jul 31, 2009 | 05:33 PM
maddghost's Avatar
maddghost
Wow good info here ! I did mine last week without a hiccup!
cruzmisl
Apr 8, 2026 12:49 PM
Subduedracer
Jul 31, 2013 10:38 PM
taygull
Apr 3, 2013 01:48 PM
hoethree
Jul 7, 2010 08:26 PM
