changing bars
Old Aug 5, 2009 | 09:12 PM
ambrose's Avatar
ambrose
Default changing bars
Just courious is it easier to cut the wires under the tank when you add mini apes, I'am putting mini apes on my super glide.
Old Aug 6, 2009 | 12:03 AM
Hickey's Avatar
Hickey
slide tank back, pull out connectors from frame, dismantle, and add an extension kit (I used Namz 8 inch). put it back together.
welcome to the forum. Btw, the search function works wonders. There are tonnes of threads regarding the procedure. Good luck!
Old Aug 6, 2009 | 01:21 AM
kk6pg's Avatar
kk6pg
Why would you want to cut or extend the wires for mini apes?
They fit the FXD without any wiring modification.
If you want to wire internally, then jack up the tank, pop the connectors, remove the wires and fish them through just the way they are.
My sig pic is with mini apes and stock wires.
Old Aug 6, 2009 | 05:38 AM
Goddahavit's Avatar
Goddahavit
yes, in my opinion its easier to cut, add whatever length you need and solder.
everyone's opinion will be different.....
Old Aug 6, 2009 | 06:10 AM
ambrose's Avatar
ambrose
Thanks everyone for the input. This is a great fourm.
TUCCI
Oct 2, 2016 07:09 PM
greghockey17
May 2, 2014 06:36 PM
harleyglen
Apr 10, 2014 01:52 PM
SonofHarley91
Dec 9, 2012 12:17 PM
Dannell53
Apr 13, 2010 12:22 AM
