tech question does anyone know....
. i prefer fuel injected over carbs.. 255 is too big for a sporty other than short hops around town in my opinion...
If its a Fatbob that came with factory forwards or a wide glide then its going to take alot of work to put mids on.
If it has a cover plate on the primary they were added after but still can depend on how they did it wether its a big job to go back or not. Some guys will cut the old shifter shaft so if that has been done it takes alot of work.
You could also consider a reach seat if got a bike that had forwards already. They will move you up some.
I just converted my bike from forwards to mids and it was a major pain in the ***... BUT, only because the jackasses that worked on my bike who put the forwards on before I got it severely F'ed up some things, which I had to pay the consequence for.
Just to give you an idea.. to convert back, you would need to take off the primary cover, remove the primary chain assembly (clutch basket, compensating sprocket, primary chain, primary chain tensioner) then the starter bolts need to come out, then the inner primary, and ALL that just for a little shift lever. SO, with that said... get a bike with mids. You'll be much happier!
The mid control dyna's are everywhere, and usually you half to go out of the way to find the ones with forwards. Plus, if they removed the shifter shaft and did the full install, the amount of work to convert back wouldn't be worth it cost wise, unless you got a ridiculous steal on a bike.
Patience.
Mike
