Lowrider front suspension
Old Aug 13, 2009 | 07:55 PM
Titan56's Avatar
Titan56
Default Lowrider front suspension
I picked up 2003 Black Lowrider with only 1500mi on it. The front suspenion sucks. I want to change the springs with out changing the height. What springs are the best and what weight fork oil should I use.
Old Aug 13, 2009 | 08:04 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Why not first change the fork oil? Go to Belray 10w or 15W. Lift the front end to extend the forks, remove the fork cap, watch out for the spring unloading, remove drain screw at bottom of fork, drain oil, install screw. add 11 ozs. The extra .4 oz. stiffens the fork a little. Install fork cap, now do other side. One side at a time. Visit Progressive Suspension site for spring info.
Old Aug 15, 2009 | 01:30 PM
2NAHNTR's Avatar
2NAHNTR
I changed the springs with new stock height progressives and it made a world of difference. I went back with stock fork oil. I weight 190, if you are a heavy guy you may want to try heavier oil. But I agree to try changing the oil first and see what happens. Its cheap and too easy.
Old Aug 15, 2009 | 03:13 PM
madden23's Avatar
madden23
I went with Works triple rate spring kit, 15W fork oil and Ricor valves, it made a huge(for the better) difference in the front. Lots of posts on this.
sioux565
Aug 5, 2013 02:40 PM
Interceptor9C1
May 22, 2012 11:23 PM
FATKEVIN
Jan 24, 2012 04:39 PM
Bagger Jim
Sep 7, 2011 11:21 AM
Shift_4lo
Jul 29, 2006 12:23 AM
