Side plate mount
Old Aug 14, 2009 | 12:58 PM
1BadAssBob's Avatar
1BadAssBob
Question Side plate mount
I'm looking for some links to find a side mount plate bracket for my 08 Street Bob. I have seen some from Road 6 Customs. Has anyone used these, & mounted them to the lower shock bolt?
Thanks!
Old Aug 14, 2009 | 01:02 PM
Bobbed Out's Avatar
Bobbed Out
i made mine from my stock license plate bracket $0.00
Old Aug 14, 2009 | 01:36 PM
bberck's Avatar
bberck
I have the Road 6 Customs Horizontal mount I got off Ebay for $16. I added a Radiantz LED frame and it turned out pretty good. I wanted to keep it legal so went Horizontal since may states are cracking down on vertical ones.
I mounted it to the inside lower shock bolt to tuck it in as close as I could. I bought a longer shock bolt and had to use 1 washer to space in it a little so the shock would clear it. I also used one washer between it and the nut. This left about 1/2 inch clearance from the shock nut to the pulley.
Old Aug 14, 2009 | 02:43 PM
Bobber S's Avatar
Bobber S
Don't waste your money on a side mount plate bracket. See my self fabricated mod.
I used a piece of metal ( got it from the bike when I did my forward control upgrade. ) but you can use any L shaped metal as a braket then simply drill and bolt to the plate frame. Can go either vertical or horizontal mount with this set up - done both.
Old Aug 14, 2009 | 04:18 PM
blacknsilver's Avatar
blacknsilver
I have the Road 6 customs on mine on the lower shock bolt. I also added some LED tags bolts for lights. Here are a couple pics.
Old Aug 14, 2009 | 06:48 PM
1BadAssBob's Avatar
1BadAssBob
Thanks guys, u given me some ideas!
Old Aug 14, 2009 | 06:59 PM
1BadAssBob's Avatar
1BadAssBob
Blacknsilver, did u have to get a longer bolt?
Old Aug 14, 2009 | 11:36 PM
blacknsilver
No, used the same shock bolt. It went on easy.
Old Dec 21, 2009 | 11:14 PM
El Chiguete's Avatar
El Chiguete
How are you running that cable for the stop light?
Old Dec 22, 2009 | 05:02 AM
Naz_Man's Avatar
Naz_Man
Jameson
Jan 8, 2015 06:43 PM
njohnson27
Sep 6, 2013 04:03 PM
nkauf21
Jun 7, 2007 11:12 PM
hdmikeshirley
Apr 19, 2007 11:27 AM
Jock !!!
VRSC Models
Feb 17, 2006 11:26 PM
