Ordered New Musting Seat
Old Aug 16, 2009 | 05:23 PM
Foodog's Avatar
Foodog
Default Ordered New Musting Seat
Debated for days now over which seat to order Mustang vs Corbin. Finally decided on the Mustang Vintage Wide Solo. I've got an 09 Low Rider and wonder if I need the seat nut kit that Mustang has.
Old Aug 16, 2009 | 06:34 PM
Tele00's Avatar
Tele00
You will use it if you want to leave the factory one in place for a fender bib or additional pad.
Old Aug 16, 2009 | 06:41 PM
jake40ma's Avatar
jake40ma
Default ???
I also ordered the wide vintage solo with backrest and passenger pillion for my fatbob. Will I need the nut? I will be teed off if this arrives and I can't immediately mount it. Please let me know if they send you everything you need to mount seat Thanks
Old Aug 16, 2009 | 07:04 PM
Baeseman1's Avatar
Baeseman1
When I got my Mustang 2 piece seat(3 yrs ago), only the pillion pad came with the nut. Obviously the seat you are using now has one, but you'll have to move it to the drivers position. If you got a seperate pillion pad, it should have a nut included. At least mine did...
Old Aug 16, 2009 | 08:03 PM
Foodog's Avatar
Foodog
I just went out and pulled the stock seat off. Looks like there is a hole in the fender that has a plastic plug in it now. I presume that is where the back of the Mustang Solo seat bolts. Is it possible to get a new mounting nut in there without dropping the rear wheel? Looks like I better call Mustang in the morning and have them include a new mounting nut.
Old Aug 16, 2009 | 08:07 PM
Tele00's Avatar
Tele00
actually they include a zip tie that you simply feed through the nut, fish it up, attach the retainer clip, and drop out the zip tie. Its easy ..... a new nut and clip and the zip tie will already be in the box with the new seat.
Old Aug 16, 2009 | 08:31 PM
Foodog's Avatar
Foodog
Dang... I never would have thought of that . I probably would have spent half a day trying to get my hand between the fender and the wheel.
Old Aug 16, 2009 | 08:37 PM
maddghost's Avatar
maddghost
I used a little duct tape on the end of a paint stir-stick,just poke the thread/nut part to the hole from betweeen the tire and the fender add the retaining clip . took longer to get the paint stick from the baement than to put it together,seriously 10 second job. The little retainer clip was a plastic snap ring.
Old Aug 16, 2009 | 08:45 PM
Baeseman1's Avatar
Baeseman1
If you're only running the solo seat, pop the plastic plug off, move the rear nut forward, and install the plastic plug in the rear hole.
Just in case you haven't done it yet- with the seat off and looking at the existing nut, there is a black plastic C clip that holds the nut in place. Tele00 is on the money - Fish a zip-tie up through the bottom of the nut and hold/tape it so it catches the nut when it falls. I use my thumbs and pop the C clip off. Lower the zip-tie with nut hanging on it, and fish the zip-tie up through the front hole. The nut only fits one way (it's obvious) and snap the C clip back on.
I have a detachable sissy bar/ pillion pad and swap out the plug/nut every time the wife goes for a ride. I can reach my rear nut and have the system down to a matter of seconds...
Old Aug 16, 2009 | 08:52 PM
Foodog's Avatar
Foodog
Thanks guys. I think I've got it figured out now.
