Stupid question
Old Aug 29, 2009 | 02:32 PM
usaztec66's Avatar
usaztec66
Default Stupid question
I wanted to ask where is the location of the oil drain plug on a 2007 dyna. I just orddered my manuel but I need to change the oil on the bike before a ride that I am doing befere it gets here. Help would be great. Thank you guys very much.
Old Aug 29, 2009 | 02:39 PM
HDDyna2006's Avatar
HDDyna2006
looking under jiffy stand, the one closer to it, it should drain about 2.5 qts, make sure you fill filter with oil.
Old Aug 29, 2009 | 02:49 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Default drain plug location
Here's how it is on my FXD2003. My guess is that it's the same with your bike.
The drain plug for the primary case is at its lower back end. Don't forget to change the oil filter as well!
Old Aug 29, 2009 | 03:02 PM
nevil's Avatar
nevil
2 more "don't forget"s- replace the o-ring, they are cheap. And, remember to put the drain plug back in. Sounds simple enough, but there's enough stories about that to write a book.
Old Aug 29, 2009 | 03:09 PM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Engine drain is oriented horizontally; tranny drain - vertically. I think if you try filling the filter before installing it, you're gonna have a mess. Just my opinion, but I am the world's leading authority on my opinion.
WS6 Formula's Avatar
WS6 Formula
There's three identical drain plugs, only two face down, one is the primary (on the primary case) and the other is the transmission.
And the one that is facing towards the kickstand side of the bike is the engine oil.
Old Aug 29, 2009 | 09:56 PM
jblank37's Avatar
jblank37
Put 4 ozs. in filter before installing and you won't have a mess.
Old Aug 30, 2009 | 12:13 PM
rayfinseats's Avatar
rayfinseats
AND IF YOU DON'T YOU'LL RUIN YOUR ENGINE. Do you want to run it for 30 seconds with no oil while it fills the filter?
lwbdriver
EVO
17
Apr 17, 2017 07:37 AM
ckgdrums
Mar 14, 2008 11:02 AM
ronster
Sep 21, 2007 04:07 PM
trmn8r
Sep 1, 2006 02:59 PM
johnpiech
Jul 1, 2006 12:04 PM
