Need some help guys
Old Aug 29, 2009 | 03:52 PM
jaysonL's Avatar
jaysonL
Default Need some help guys
After reinstalling the wheels and tires on my bike, I now have all most no rear break. I never touched the break pedal while the wheels were off, the caliper rested nicely on the swing arm the whole time, reinstall went smooth. Just now I have no rear breaks. Thoughts ?
Old Aug 29, 2009 | 03:57 PM
skip3406's Avatar
skip3406
Bleed the rear brake
Old Aug 29, 2009 | 04:07 PM
jaysonL's Avatar
jaysonL
Just did that. Still don't have much break to speak of.
Old Aug 29, 2009 | 05:03 PM
Ratbob's Avatar
Ratbob
Could bet the rear master cylinder piston. Remove the top of the reservoir and pump the brake a few times. You should eventually see a bubble or a pulse of fluid rising from the small hole in the bottom of the reservoir each time your release the brake pedal.
Also - could you have contamination on the pads?
Last edited by Ratbob; Aug 29, 2009 at 05:05 PM. Reason: After thought - contamination on pads?
Old Aug 29, 2009 | 05:54 PM
jaysonL's Avatar
jaysonL
When I bleed the break, I get a ton of fluid, so it would seem to me that the master cylinder is working fine. One thing I just thought of. When the shop had the wheels, and replaced the tires, they marked the rotor, front, and back wheel, with a directional arrow. I can only assume to help them know which way to mount the tires. When I put the wheels back on, I sprayed the rotors with break cleaner and removed the marker. I did the same to both wheels. The front breaks work just fine. That's the only other thing I did. Could this have glazed the pads/rotors ?
Old Aug 29, 2009 | 06:29 PM
jmpancoast's Avatar
jmpancoast
Just because you are moving fluid doesn't mean there is not air in the lines.
If the pedal is soft, keep bleeding them. A hand operated vacuum pump works great.
Old Aug 29, 2009 | 08:02 PM
jaysonL's Avatar
jaysonL
That's just it. The pedal isn't soft. In fact, it just the opposite. It's rather hard, and little movement, or "push" .
Old Aug 29, 2009 | 08:20 PM
Sandhog's Avatar
Sandhog
Must be something with the pads,double check them,it seems like perhaps one is missing or bound up in the keeper.
Old Aug 29, 2009 | 10:11 PM
Phrogman's Avatar
Phrogman
Just out of curiousity, did you have to spread the pads when you put on the rear wheel? Most of the time when I let my calipers sit I have to spread them a bit when trying to get the rotor back in there.
Also, to ask the obvious, you do have two pads in there right? You might think it's a dumb question, but I did see a guy put his wheel on once with only one pad in the caliper. The back one fell out and he didn't notice.
Old Aug 30, 2009 | 05:50 AM
jaysonL's Avatar
jaysonL
I'm 99.9% sure there are two pads there , but I will check. I didn't have to spread the pads when installing the wheel.
