Corbin primary inspection cover leaking
Old Sep 13, 2009 | 09:28 PM
Malibyte's Avatar
Malibyte
Default Corbin primary inspection cover leaking
Hey all -
I have an aftermarket primary inspection cover from Corbin (the one with the fill port). I put it on about 3000 miles back, and it's been fine until a week or two ago, when it started leaking from around the 7:00 position. I took it off, checked the gasket (it's good; aftermarket one is bigger than stock); the cover itself is still flat (it's a lot thicker than the stocker so is less likely to warp); even got some new (longer) bolts. Damn thing still leaks (quite a bit, now).
Anyone else have this problem and have a fix for it? I'd rather not buy another stock one if I can avoid it.
Thanks.
baka1969
Oct 5, 2023 05:31 AM
hog95023
Jun 30, 2013 04:11 PM
DDuess
Aug 11, 2012 12:37 AM
trip20
Aug 6, 2010 03:14 PM
Arizona
Mar 18, 2008 07:45 AM
