Odometer Diagnostics check??
Old Sep 14, 2009 | 11:38 AM
06WGRider's Avatar
06WGRider
Default Odometer Diagnostics check??
Went on a benefit ride Sat. At the break point getting ready to continue I started up the bike (06 FXDWGI). While it was running I noticed that no milage was showing on the odometer. It was blank. Pushed the reset / trip button and all of a sudden the odometer is showing a diag check format. Anybody have any ideas? If I recall right it showed diag then I pushed the reset again and it showed ppst (don't know if those were the actual letters but regardless the first letter was flashing. Am I nuts?? Anyway, turned the ignition off then back on and all was fine and back to norm. Should I be concerned? Figured I would reach out in the forum prior to calling the dealer who will require I bring it in for a check.
Old Sep 14, 2009 | 01:03 PM
0lowrider1's Avatar
0lowrider1
might have just been one of those things that happen...the run/stop switch has to be on run....the trip reset has to be pushed in while the ignition is turned on...it probably said..diag..push the button it went to psst..no big deal........
Old Sep 15, 2009 | 06:23 AM
06WGRider's Avatar
06WGRider
Exactly, thank you. I do recall the first p flashing. Thanks again
Magnut1
2014-2024 Touring Models
Nov 26, 2014 09:44 AM
steelerdude1
Jul 22, 2012 04:16 PM
DPete
Nov 12, 2011 03:07 PM
skos
Apr 13, 2011 05:12 PM
EricM
Jul 5, 2008 08:37 PM
