Hazards flash upon startup
Old Jul 3, 2008 | 06:00 PM
EricM's Avatar
EricM
Default Hazards flash upon startup
I recently had my bike tuned with the Twin Tec TC88A ignition module and I have noticed that when I click the start button and the engine light comes on, the hazards will flash several times then stop. The bike cranks fine and runs fine. Is this a common occurance with the module?
Thanks
Eric
Old Jul 3, 2008 | 06:03 PM
ChefE's Avatar
ChefE
Default RE: Hazards flash upon startup
When the flashers blink 5 times when you switch the run switch to on, it means that a diagnostic code has been thrown.&nbsp\\; You can check the codes on the speedometer in diagnostic mode.
Old Jul 3, 2008 | 06:52 PM
cHarley's Avatar
cHarley
ORIGINAL: ChefE
When the flashers blink 5 times when you switch the run switch to on, it means that a diagnostic code has been thrown.&nbsp\\;\\\\\\; You can check the codes on the speedometer in diagnostic mode.
+1 - I haven't seen the problem with my TC88A.
Old Jul 5, 2008 | 08:37 PM
EricM's Avatar
EricM
How do I check the codes on the speedo?
risdo
Sep 29, 2013 09:15 AM
steelerdude1
Jul 22, 2012 04:16 PM
dennyo
Aug 17, 2010 08:56 PM
Tanker2
Apr 16, 2008 02:40 PM
RMBob
Aug 15, 2006 10:09 PM
