??? about turn sigs??
Old Jun 17, 2006 | 11:22 AM
rickshog's Avatar
rickshog
Default ??? about turn sigs??
On my 06' dyna I want to get rid of the brake light and put red covers on the turn signals and use them as turn signals and brake lights. Is that possible??? Thanks
Rick
Old Jun 17, 2006 | 11:57 AM
jackyl's Avatar
jackyl
Default RE: ??? about turn sigs??
yes i did it with my streetbob,you just have to buy the module.its cheap only like 35.00.real easy to install to.take about 5 minutes to do.Name:  3.jpg
Old Jun 17, 2006 | 12:00 PM
rickshog's Avatar
rickshog
nice!!!! and where can that be found????
Old Jun 17, 2006 | 12:26 PM
jackyl's Avatar
jackyl
at the dealer.kit comes with the the 2 red lens and the module.not sure what the part # is.just ask them a the counter.
Old Jun 17, 2006 | 01:11 PM
phreak's Avatar
phreak
Happen to have any pix of that setup?
Old Jun 17, 2006 | 01:55 PM
jackyl's Avatar
jackyl
of how its installed?all you do is take off your seat.and grab the main wire harness,its labeled.disconnect the wire harness and plug in the module to one end of the harness,then plug the other end of the harness in the module,works as a piggypack.then put the red lens in turn signal housings.and your done.take less then 5 minutes.very simple and easy to do,and real cheap good mod.i like them,because jacka&&es behind you,can see you alot more.and looks real nice to.Name:  6.jpg
Old Jun 17, 2006 | 02:01 PM
TOMMAY's Avatar
TOMMAY
ORIGINAL: phreak
Here's a pic with the factory set up. Sure lights up at nite when you apply the brakes. They also make a replacement for the stalks that is exactly the same,just shorter to set the lights in closer to the fender. I really don't mind the looks of these. I want to be seen when I hit the brakes.
[IMG]local://upfiles/8936/ED08A45E01494F4E8294AF6CF704CE85.jpg[/IMG]
Old Jun 17, 2006 | 02:02 PM
rickshog's Avatar
rickshog
looks nice... Im guessing that its not too much trouble to ditch the big brake light and just use the stock turn signals for brake lights right??
Old Jun 17, 2006 | 02:07 PM
jackyl's Avatar
jackyl
iam not sure if the module will let you.i guess you could try it.i like it cuz it gives me 3 running lights and 3 brake lights,instead of just the big brake light.almost got rear ended a couple times,since i changed it,they can see me better now.
Old Jun 17, 2006 | 02:15 PM
phreak's Avatar
phreak
ORIGINAL: rickshog
This is what I was asking phor pix of. A bike with no tail light, and just the turn signals.
