IPB-How do you know it's shot? (Sorry long read)
be patient. The upside is you'll be all fixed up when theyre done
Rick, are you sure the inner cover drillings and the trans drillings line up? I'm wondering if theyre for 10mm alignment pins or if they were for jig plate alignment during the machining process. Cant tell by the photos if they're actually bolt holes or not. If they are, try 10mm or 3/8's sleeves and go for it.
Here's the noise maker.......
Makes you wonder if it's really an alignment issue or just junk bearings.
I like the full bearing that Baker and Jim's uses. The only downside is the inner race isnt pressed onto the input shaft, which could be a good thing as long as the bearing gets plenty of oil. I havent seen one fail yet, but I havent seen that many in use either (or at least ones that need to be torn apart).
Also, 10mm mics out at .394. Next size up is 7/16ths (11mm) at .435 (.433)
Try a 10mm OD split sleeve, open it up with a screw driver and jam it in the hole (friction fit).
And your plastic caliper is just fine. It will give you the same ball park reading my NSK will
Got a call today from the dealership. Tech support in Milwaukee is sending an entire gear set for installation. When? They could not tell me. They feel that it is an alignment problem. So I called Milwaukee to get an ETA.
Takes 5 days before they ship and then they ship ground only... no ifs ands or buts. So I'm at leat 10 days before they begin work. Customer service could care less. I am seriously disappointed.
Customer service does NOTHING for their customers. I'm starting to hate my bike. My guess is you'll find me on the Raider Forum as soon as my bike is fixed. I know it's not a Harley but I need the wind in my face, I need reliability and I need a company that gives a s***. Arrrrrrrrrrrrrrrrrrrg!
