Will it fit?
Old Sep 17, 2009 | 01:37 PM
ghostrider69's Avatar
ghostrider69
Default Will it fit?
Alright, before I go to tearing into this maybe ya'll can help me out here. Just got off the phone with an old friend and he has a new replacement 21x2.15 chrome wheel assembly for a 2006 FXD. He is wanting to do a straight up trade for my ugly azz black rim setup. It is a dual flange hub with 1" bearings. Will this wheel fit my 09' StreetBob if I change out the bearings to the newer 25mm size.
Old Sep 17, 2009 | 01:44 PM
Phrogman's Avatar
Phrogman
Sure it will, but you will need to make some custom spacers (or buy some of the right size) and ensure your caliper is centered.
Old Sep 17, 2009 | 01:46 PM
arkieollie's Avatar
arkieollie
The wheel will fit with the new bearings but you will probably have to alter the spacers....either grind the stock ones down or add some "washers" .
I put an 09 hub on my 07 and after I changed the bearings and the wheel was off center with the stock spacers. I had some stainless steel washers chromed to "re-center" the wheel. I have heard of others grinding down the stock spacers to center.
Old Sep 17, 2009 | 01:58 PM
Mascman's Avatar
Mascman
Would it work to swap the spacers that go with each wheel or are they different inner diameters?
Old Sep 17, 2009 | 02:29 PM
ghostrider69
The spacers are differant inner diameter. I guess I will call him back and tell him we'll do the swap. That will be one more thing marked off the to do list.
Old Sep 18, 2009 | 07:02 PM
ghostrider69
Alright guys. I am going to pick up the wheel assembly Sunday. My question is which wheel do you all think would be best for looks and performance on this 21x2.15 rim?
Avon: 80/90 21 or 90/90 21 or MH90 21
Metzler: 80/90H 21 or 90/90H 21 or MH90 21TL
Never been much on tire sizes so if someone could explain the differance between the 80/90 and the 90/90. Is the 80/90 a lower profile?
Old Sep 18, 2009 | 07:37 PM
ackman1968's Avatar
ackman1968
As far as the diameter of the spacers, it's not that much. 1" = 25.4mm, I bet you could use them.
Old Sep 18, 2009 | 08:15 PM
jmpancoast's Avatar
jmpancoast
The difference in the spacers not only lies in the inside diameter, but also the width. The 25nmm bearings are narrower, so the spacers will need to be wider.
Easiest fix, use your existing spacers, and let him use his OEM spacers. Once the correct I.D. bearings are installed, the spacers will be right.
Old Sep 18, 2009 | 08:35 PM
ghostrider69
Good point. What size tire are you running on the front?
Old Sep 20, 2009 | 10:27 AM
ghostrider69
oops!
