inner primary... what a mess!
everythign came apart pretty simple... problems where... alot was gone... my shifter shaft seal was done.. no big deal ill get a new one...
IF YOU HAVE NOT CHECKED YOUR INNER PRIMARY BEARING -> DO IT!!!!
mine was so screwed up that the inner race had moved against the trans output shaft... the race had actually smashed itself into the seal and the clutch must have had a whoble... so i was able to find an old gear puller my dad used before electricity was invented to pull his superglide clutch in the 70's... chad welded that to the race, and we where able to pull it off... sounds like it took 2 min... well it did not, i then had to fish out all the old parts that where left in there. the Baker high torque bearing comes with all the good stuff i need to replace it... i still need to get a new shifter shaft bearing, trans output oil seal, and starter shaft o-ring and i should be able to button it up. Turns out all that oil i was blowing all over my buddies riding behind me was not only from a tower gasket, but also my shifter shaft seal, and the trans output gasket... the trifecta!
she is still in parts. here are some pics of our night
SOME good news! no bolts to weld! it is one solid piece
you can see how far on the race had been forced
getting the clamp lined up to pull off the race
welding the clamp on to try and pull off the race
chads prize for awesome welding
what was left of my trans oil seal
here she sits waiting till tomorrow and some more parts come in!
I've ran across that before tearing into a transfer case on my cruiser. Not fun.
How many miles do you have the on the scooter?
Also, you have a pic of the rotor, not the stator that needs to have the screws welded. How's the other parts look?
Once we started pulling it, we found out it was sitting inside the outer shaft about 1/4" so I dont know if it would have worked because we wouldn't have been able to cut very much of it. It might have still cracked though. I guess there really is more than one way to skin a cat.
Mike
Glad you caught those issues before they caused a major problem but I swear I am going to have to stop reading this forum or I am going to worry myself to death every time I ride.
