Pause when starting
Old Oct 22, 2009 | 12:36 PM
Zinje's Avatar
Zinje
Default Pause when starting
Lately i noticed that it takes a itty bit longer to start the bike. When i hit the start button it pauses about a second then start. Sometimes it would crank once, twice or even three times then finally start. I checked my battery and the connection is good. Any ideas? The bike is an 07. Do you think the battery is going bad?
Old Oct 22, 2009 | 12:49 PM
rounder's Avatar
rounder
may want to get it load tested. If it is two + years old there is a good chance it is.
Old Oct 22, 2009 | 12:52 PM
tab69pr's Avatar
tab69pr
mine just did the same thing, if the battery starts to run low it will slug upon start up! i replaced the battery and back to normal.
Old Oct 22, 2009 | 12:59 PM
2007fxdc's Avatar
2007fxdc
Mine is an 07 and it's starting to do the same thing. When I hit the switch, it'll turn over once real quick, pause, and then start right up. Battery is 3 years old next month so I figure it's time to get a new one - just haven't done it yet. I usually don't go far this time of year and rarely stop somewhere and shut it down before coming back home. So, if it dies, it's likely to be dead before I leave home. However, usually when it has warmed up and I've ridden a little ways, it'll crank right up without the pause.
Old Oct 22, 2009 | 01:01 PM
JRK5892's Avatar
JRK5892
do you wait for your fuel pump to prime? when is the last time you replaced your plugs
Old Oct 22, 2009 | 07:59 PM
RaoulDuke's Avatar
RaoulDuke
Did you put a voltmeter on the battery? My guess is that you need a new one. My Wide Glide was doing the same thing. New battery. Problem solved.
BTW, it was the original battery...on an '02. So, IMHO, shell out the extra bucks and get an OEM battery. [EDIT: I put the new battery in yesterday]
Old Oct 23, 2009 | 12:08 AM
Zinje's Avatar
Zinje
Coolio guys! I'll checkout the battery and the plugs.
xenafire
Electrical/Lighting/Alarm
Feb 23, 2023 11:37 AM
Titan307
Oct 17, 2013 09:30 PM
mikerm250
Jul 5, 2010 05:06 PM
E DOGG
Mar 2, 2007 12:25 AM
LordVngr
Exhaust System Topics
19
Aug 22, 2005 06:49 PM
