Anyone change their brake fluid?
Old Oct 24, 2009 | 12:12 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Originally Posted by jousley
thanks for the speedbleeder link.. that little thing rocks.. gonna get one.
J.
Just make sure that when you bleed them you only open the bleeder 1/4-1/2 turn from tight. Put a hose over the bleeder. remove the fill cap and pump until you have replace all the fluid. Close bleeder, remove hose, replace & tighten cap...done. Clean off any brake fluid because it will eat paint, powder coat & plastic. I clean it off with brakleen & then simple green & warm water.
Old Oct 24, 2009 | 06:00 AM
Slayer dude's Avatar
Slayer dude
Thanks for the link. I had no idea that I should change it, now more stuff on the to do list.
Old Oct 24, 2009 | 10:56 AM
archergodwin's Avatar
archergodwin
I changed mine out at 3K when I did the mini apes and chrome controls...etc.... amazing the amount of crap that was in there, and coloration already.... Went ahead and did the rear when I saw all the crap come out of the front.
Then did them both again, when I put new cables/lines on.... about another 7K when I did those. Not quite as bad as the first flush.
Old Oct 24, 2009 | 11:15 PM
pennetta's Avatar
pennetta
Originally Posted by KBFXDLI
Get a set of speedbleeders and install them. You can flush your brakes in 20 minutes.
http://www.speedbleeder.com/
I flush my brake system every season. very easy to do with the speedbleeders.
They don't seem to have speedbleeders for an 07 FXDB?
Old Oct 24, 2009 | 11:42 PM
rounder's Avatar
rounder
sb3824 is the part #. Both front and rear.
Old Oct 25, 2009 | 09:39 AM
YellowHawk's Avatar
YellowHawk
Glad I read this thread. I need to do this too.
Old Oct 25, 2009 | 10:29 AM
SilverV's Avatar
SilverV
...and of course, when you're pumping the lever or pedal, don't let the fluid in your reservoir get to the bottom before refilling...
Sometimes the obvious ain't so obvious. Just sayin'.
Old Oct 25, 2009 | 01:10 PM
pennetta's Avatar
pennetta
They sound great once they are on. How do you install them without emptying the brake fluid out and letting air in?
Old Oct 25, 2009 | 01:14 PM
pennetta's Avatar
pennetta
Is it SB3824 or SB3824HD?
Old Oct 25, 2009 | 02:26 PM
rounder's Avatar
rounder
I was gonna say sb3824HD ,but, they have to 06 on there. I would contact them to find out.
