10 MM Plug Wires?
Old Oct 24, 2009 | 11:59 AM
Frog33's Avatar
Frog33
Default 10 MM Plug Wires?
Hey All,
I have seen many switching to 10 mm pulg wires, and was just wondering if making the switch is as easy as changing the wires or are there any other recommendations to go along with this mod? Thanks All
Old Oct 24, 2009 | 12:23 PM
last saint's Avatar
last saint
I have 10mm plug wires on my personal bike. It's basically just cosmetic. The core is supposedly no bigger than an 8.8 core. Just more insulation. That's what I've been told anyways.
Old Oct 24, 2009 | 12:44 PM
Lorance66's Avatar
Lorance66
zero performance gain from doing it first of all, just so you know. But if you can pull a wire and push one back on, it is that easy. No remaps required or any of that stuff in case you are wondering.
Old Oct 24, 2009 | 01:26 PM
Frog33's Avatar
Frog33
thanks for the info. I didnt think it would be hard, was just wondering what the gain was. Seems to be a mod I will do when I run out of other things to spend my money on. Thanks again
Old Oct 24, 2009 | 01:35 PM
BIGDADI's Avatar
BIGDADI
I thought I heard changing the plug wires to less resistive ones messes with the spark knock sensor system or something along those lines???
Old Oct 24, 2009 | 02:49 PM
US66harley's Avatar
US66harley
I think most agree it's just one of the cheaper appearance mods you can make. No performance or any other gains.
Old Oct 24, 2009 | 04:40 PM
2007fxdc's Avatar
2007fxdc
Purely cosmetic and it's as easy as just changing the wires yes. Just make sure you take the time to secure the new wire to the front cylinder back to the horn bracket like the stock one is. The new wires dont' come with what you need to do that. Easily doable with simple tie straps/
Old Oct 24, 2009 | 06:30 PM
archergodwin's Avatar
archergodwin
Yeah, no gain.. just looks. But make sure you get wires that are listed as compatible with the Delphi ECM, if you want to retain the anti-knock feature.
Old Oct 24, 2009 | 07:00 PM
Desert Hog's Avatar
Desert Hog
+25 HP for the wires, +65 if ya throw on a chrome Air Cleaner!
kingjoey5000
Jun 14, 2013 01:40 PM
barrachuck
Mar 10, 2010 05:52 PM
1200efi
Jul 6, 2008 09:35 AM
blackness
Feb 14, 2008 06:20 AM
2006ultra
Apr 28, 2007 11:27 PM
