What do you clean the rocker covers with
Old Oct 29, 2009 | 07:39 PM
pennetta's Avatar
pennetta
Default What do you clean the rocker covers with
Are the rocker covers clear coated? What do you polish them with. Also noticed that the bolts on the engine are oxidizing, what do you use on them? What about the machined cooling fins on jugs?
Old Oct 29, 2009 | 08:01 PM
Double00Aught's Avatar
Double00Aught
A tank lift gives nice clearance for front rocker cover cleaning. Mines are chrome so I wash with soap and water and polish with a good chrome cleaner. I'd scrub those bolts with some WD-40 and an old tooth brush.
Old Oct 29, 2009 | 08:19 PM
SuperFastGlide's Avatar
SuperFastGlide
mothers for mine
Old Oct 30, 2009 | 10:17 AM
sintax's Avatar
sintax
I used powder coat! :P
Old Oct 30, 2009 | 10:33 AM
SC-Longhair's Avatar
SC-Longhair
are your rockers chrome or aluminum? You have to know at least that much before you attempt to clean them.
Are they really shiny or look more like your triple trees (those things your handle bars and headlight is attached to)?
If shiny, they're chrome...and you use chrome polish. If they look like your front end, use aluminum polish such as Mother's.
Old Oct 30, 2009 | 01:16 PM
rdondes's Avatar
rdondes
All chrome can be nicely cleaned with isopropyl rubbing alcohol that is cheap and available at any drugstore or supermarket. This includes heat shields, rocker covers, lifter blocks, chrome primary, etc. etc. After cleaning, you can polish with your favorite polish.
Old Oct 30, 2009 | 02:37 PM
bigdaddy33's Avatar
bigdaddy33
S&S Cleaner and Polish. Sprays on and does a nice job on chrome and painted surfaces. Quick and easy.
Old Oct 30, 2009 | 04:50 PM
cornishman's Avatar
cornishman
Looks like your covers are bare so the aluminium polish of your choice. I use Maguiars which works well.
Old Oct 30, 2009 | 07:25 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
The aluminum is not clear coated.
Old Oct 31, 2009 | 07:58 AM
K9pusher's Avatar
K9pusher
I apply aluminum polish with my fingers and then polish with a microfiber cloth. I use my fingers to apply polish because it gives me more control of where I the polish goes.
