06 Dyna dangling wire
Old Jul 7, 2006 | 01:27 PM
johnpiech's Avatar
johnpiech
Default 06 Dyna dangling wire
Size:  82.4 KBName:  rightround.jpg
I hope you can see this, only my second post with pictures. I left big so you can see more detail.
When I did oil change #1 over the weekend, I noticed this dangling wire. It was wedged between the rear cylinder and the injector body, and was actually starting to melt the protective sleeve - ouch. I looked up, down, all around, and could see no place to plug it into. It has a plastic theaded bolt attatched to it. After some long thought, I have come to the conclusion that the plastic bolt piece must have snapped into the original backing plate (I have the SE plate and cleaner) to keep it out of harms way, and that since the end is "capped" - that its purpose must be for running some kind of diagnostic when needed, or a hook up for accessories I don't have (like a tach)? I routed it around the injector body in front (as opposed to where it was wedged between the injector and cylinder), and then up near the top of the backing plate where I zip tied to a metal collar the intake manifold runs through.
Did I do the right thing here, and can anyone confirm that riding with this wire plugged into nothing is OK?
I have the teclusion mixer on my bike too, not sure if that matters.
1550 kit, cams, SE air cleaner, SE pipes, techlusion mixer - this is my config.
I noticed some gasket cement/yamabond type stuff had oozed out between the intake stack and the backing plate (from when the installed this when I bought the bike), much worse in the spots you can't see in the jpeg. I put a rag in the intake, and gently used a razor to cut off all the excess and make it flush between the two parts. I'm sure it was worth 1/100th of a horsepower.
Also, here's a pic of the old school Harley round cover I used rather than the phootbal stocker. I thought it looked good on the old styled FXDI35.
Thanks.
Old Jul 7, 2006 | 01:46 PM
kimo's Avatar
kimo
Default RE: 06 Dyna dangling wire
All i can say is i have the old football intake cover and the same wire keeps falling out of a hole in the backing plate.. So, i had come to the same conlusion as you have, about what it is for.
Hope this helps you.
Old Jul 7, 2006 | 01:49 PM
johnpiech's Avatar
johnpiech
Thanks - I suspect it was just something the tech overlooked when putting on the SE plate, and I never noticed until it worked its way down to where I finally saw it.
Old Jul 7, 2006 | 01:52 PM
killer.com's Avatar
killer.com
When I installed the SE kit on my 06 Wide Glide I found the same wire and I just folded it over and wire tyed it up out of the way.
Old Jul 7, 2006 | 01:53 PM
rap87's Avatar
rap87
06 FXDWG, I got that samn damn wire hanging from mine. Football Air Cleaner. It usually rests on the edges of the cleaner and I don't see it. I am interested in what its for too?
Old Jul 7, 2006 | 02:03 PM
Rubberduck's Avatar
Rubberduck
Hey JP! As they say...the angle of the dangle...
Old Jul 7, 2006 | 02:21 PM
DDC1225's Avatar
DDC1225
Refer to my post
Check out the replies to my question about this from Mud and Dan B.
Old Jul 7, 2006 | 02:26 PM
glebo's Avatar
glebo
I had the same dangler, that little threaded like plastic portion did snap into the old plastic backing plate. All I did was zip tie it up and out of the way. What its for..who knows, I dont have a shop manual to look it up. But as long as it doesn't touch anything that will melt it, you good to go.
Old Jul 7, 2006 | 02:28 PM
johnpiech's Avatar
johnpiech
Cool - I suspected the same - but appreciate all the feedback. Is that photo of the rubberduck Mr Road king?
Old Jul 7, 2006 | 02:51 PM
mud's Avatar
mud
ORIGINAL: johnpiech
I do believe you did the right thing John.
I have been told the wire is for emissions on California and/or the export bikes.
mud
