Shudder on an 09 FB
Old Oct 31, 2009 | 09:07 AM
HogNewbie's Avatar
HogNewbie
Default Shudder on an 09 FB
I have a really bad shuddering problem on decel. It's not coming from the brakes as you don't have to apply them to get the vibration. You only have to let go of the throttle and leave the clutch out.
I am posting here as I have had it at two steelerships and niether can find the problem. I have tightened down the engine mount bolts so I know the the mounts are tight but the problem is still there and I have run out of ideas.
Has anyone else had this issue? Any sugguestions on what else to look for?
Old Oct 31, 2009 | 07:57 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Acouple of things come to mind, are both plugs gapped the same (you'd be surprised) and does the primary chain have the correct tension, possibly faied auto tensioner. The primary case has to come off for to check the chain. Sometimes a chain will bounce up and down during the decel and the vibes are felt down by your feet.
Old Oct 31, 2009 | 09:13 PM
nevil's Avatar
nevil
Did you check the rear engine mount as well as the front?
Old Nov 1, 2009 | 11:58 AM
HogNewbie's Avatar
HogNewbie
Angry
haven't gone to the rear one yet....having a little trouble seeing the bolts...going to get a service manual today.
D1gger
EVO
20
Aug 29, 2012 02:41 PM
outlawrider
Sep 6, 2010 07:55 PM
creekhed1
Apr 19, 2009 06:02 PM
flyingard
Exhaust System Topics
Feb 14, 2008 03:53 PM
Tech2
Sep 22, 2006 08:45 PM
