Front Exhaust Came Loose
Old Nov 3, 2009 | 04:53 AM
YellowHawk's Avatar
YellowHawk
Mascman, actually I just took one of them to work and got a couple of nuts from there. I got some 5/16-24 lock nuts and also some 5/16-24 castle nuts. Not sure if I should use the lock nuts or not. I'm afraid the lock nuts may have too much tension and snap the stud. I think I may just use the castle nuts and use lock washers. Either way I have what I need to fix it now.
Old Nov 3, 2009 | 05:58 AM
OldFenderGuy's Avatar
OldFenderGuy
Never have used a torque wrench, just use a star lock washer, snug down the bolt, and then snug it down again after riding for a 100 miles or so..
Doing that you shouldn't have any problem with them coming loose.
Old Nov 3, 2009 | 06:21 AM
arnold's Avatar
arnold
Yeah I just had my pipes off, Ill tighten them again next week, never did more than that.
Old Nov 3, 2009 | 06:59 AM
Mascman's Avatar
Mascman
I probably wouldn't use the locknuts either as I think you may be right. If the stud gets all corroded and rusty, it may be a bitch to get off.
If you want to double nut it, you can always just use a lockwasher between 2 standard nuts and you'll be pretty bulletproof.
Old Nov 3, 2009 | 09:06 AM
YellowHawk's Avatar
YellowHawk
I think that's exactly what I'll do. Lockwasher between two standard nuts.
Old Nov 3, 2009 | 10:18 AM
INJEKTER's Avatar
INJEKTER
Originally Posted by Mascman
Seriously? You would order two nuts from Harley instead of just taking one to the hardware store and matching it up?
Make sure to order the Screamin' Eagle stainless ones!
plus 1, its nuts and bolts, just get stainless everyone carries them, Home depot carries them.......those dudes at the dealership will be laughing back there behind the closed door.
rockajet1
Engine Mechanical Topics
May 12, 2015 09:08 AM
HyperM3
Aug 10, 2013 08:05 PM
otter8
Mar 29, 2011 06:09 PM
craigffb
Aug 17, 2010 02:43 PM
brettnbama
Aug 9, 2009 08:38 AM
