Best headlight upgrade?
Old Nov 12, 2009 | 09:49 PM
Lorance66's Avatar
Lorance66
Silverstar bulb. You will like it.
Old Nov 12, 2009 | 10:43 PM
RAWHIDE07's Avatar
RAWHIDE07
Post
Good call,I went with the silverstar H4ST bulb which was a nice improvement,later I installed a fatboy 7" headlight with the same bulb which gave a wider spread.If I decide to improve my night lighting even more I will add a set of driving lights.After all if you have the best,most expensive headlight available,and it fails,you are in the dark. Much better to have a secondary set of lights,think about it.Lots of places to mount a set of small,bright,halogen lamps.
Old Nov 13, 2009 | 02:25 AM
LWOS's Avatar
LWOS
I replaced my headlamp with Harley's 5 3/4 Bullett style and use the PIAA Xtreme White bulb. I'm well pleased with the brightness. PIAA also is vibration resistant where the Sylvania isn't. Hubby and Daughter both use the PIAA in all 3 of their headlamps on their FLSTC. Last year, I also had installed HD's engine guard mounted Halogen fog lamps. You can see me coming a mile away day or night.
Old Nov 13, 2009 | 10:15 AM
RAWHIDE07's Avatar
RAWHIDE07
I had a piaa,it lasted 3 months,my silverstar is over a year old.DON'T buy the silverstar h-4 meant for cars,the correct bulb for mc use is the H4ST.I had to order mine from amazon.$36 for two.
Old Nov 13, 2009 | 12:20 PM
rockabillygrl's Avatar
rockabillygrl
What do you need to use the fatboy headlight on a street bob? I have been thinking about replacing my headlight for about a week now. This thread came at a great time!
Old Nov 13, 2009 | 05:30 PM
MyBeerBelly's Avatar
MyBeerBelly
Originally Posted by rdown1976
Yup that's the kit i got
Old Nov 13, 2009 | 06:47 PM
RAWHIDE07's Avatar
RAWHIDE07
I simply bought a comeplete used fatboy headlight with wiring and mount and it was plug&play.There have been several good threads here in the dyna forum on this subject that you should be able to find with the search feature.
Old Nov 14, 2009 | 02:46 PM
LWOS's Avatar
LWOS
Rawhide07.......
Wow, only 3 months? You have to be very careful installing them. If you get ANY finger OILS on the bulb itself, they WILL FAIL EARLY. Any halogen type bulb will warn you about that. You cant install them like a normal bulb.
We installed a total of 7 PIAA bulbs in 3 bikes in the Spring of 2007. As of the Fall of 2009, NONE have failed. I have seen the Silverstar's and they're nice ones too. The only reason we went with the Piaa, was the claim they're vibration resistant......and you know how Dyna's vibrate.
Old Nov 14, 2009 | 06:38 PM
kiltiemon's Avatar
kiltiemon
There is MORE to considering a "Light" than the just the candlepower output. WHAT you actually DO with the "light" you have is every bit as important.
I'm using 100/90 Quartz/Halogen in my car, that's just the light source. My reflector/lens combination is a high quality cut European Code. E-code reflector/lens combos are available for harleys (IIRC). The E-code puts out a flatter, wider beam (both high and low)than the standard US system, and gives an additional upsweep of light to the right. It puts more light where it's actually needed without blinding an oncoming driver. The car also has equally vicious fog and driving lights. The bike is an ongoing project, but will eventually sport the same (relatively speaking) degree of lighting.
You can also replace all the wiring involved in the lighting system to heavier wiring and better connections, as well as using relays in appropriate applications. Inadequate wiring can't get the amount of power to the bulb that it often requires!
Other than that I'm absolutely bamboozled by all the light emitting sources there are out today... My info on the relfector lens, however, is spot on!
Jim aka kiltiemon ("and there was LIGHT!!! And it was GOOD!!!)
Old Nov 14, 2009 | 07:40 PM
rdown1976's Avatar
rdown1976
What is that little thing over the bulb?
