High octane
Old Nov 15, 2009 | 11:12 AM
  #31
Foodog's Avatar
Foodog
How about you prove everyone wrong. Empty the gas tank and fill up with your regular 92 or 93 octane. Run it for a bit and then put the bike on a dyno. Empty out the tank and fill up with your "super" blend and repeat the dyno test. Be honest and post up pictures of the two runs to show the "performance" increase.
Old Nov 15, 2009 | 11:33 AM
  #32
arnold's Avatar
arnold
That sounds like a GREAT idea! But since I'm already convinced and its not important to me to go to any length to prove it, you put up the price of the two runs and the $10 a gallon fuel and Ill even have the results certified and notarized, he he he.
I don't know what is so hard to grasp. if you regularly run 93 and drop it to 91 you will probly notice a difference unless you have a dead ***, so what is so hard to accept that there is a difference between 92 and say 98? Ill say it one more time, I'm not saying anything about running 105 except as a mix ( 1 1/2 gallon in a full 5 gallon tank).
I don't have a dead ***, I can tell a difference, and a pretty good one at that, my head is really f*&(king with me to imagine the benefits I claim, I really need to check into Terrel asap and get on some Xanex or something I think I'm loosing my mind. I don't know if or how much actual HP (if any) is gained, but it runs a whole lot better.
Old Nov 15, 2009 | 11:57 AM
  #33
Faast Ed's Avatar
Faast Ed
I would wager my money that he would win that bet! You would likely be eating your words Foodog. (calling him a liar and all).
As I said earlier, in the post that you chose to ignore,.... he has a canned map in there that is likely favorable to the higher octane.
PCIII USB Custom advanced map from fuel moto
His bike was not custom tuned on a local dyno with local fuel. He likely has more advance on it. You can do the same advance to your own bike and gain a lil power, but then you'd be married to the higher octane.
It's really not that complicated.
Old Nov 15, 2009 | 03:19 PM
  #34
screamin 110's Avatar
screamin 110
Advancing the timing does not always give you hp. People think more advance gives you more rpm WRONG it does not. You guys could do your self a favor and do some tuning research. Then you will save some money by NOT buying race fuel and other gimmicks that claim hp and mpg.
Old Nov 15, 2009 | 03:39 PM
  #35
Faast Ed's Avatar
Faast Ed
Very true. Your cam and compression plays a huge role in that.
I had one cam (SE 204's) that actually gained power from taking away timing. But that was against the norm, that cam has +8 out of the box built into the cam.
But in many cases, adding timing will indeed add power (not rpm). The tuners often add timing til it pings then back off. High octane fuel allows them to push that limit a lil farther.
The only way to find out is to get it on the dyno and start playing with the AFR and Timing.
There is a place for high octane and don't try and say that there ain't.
But if you aren't playing the 1/4 mile timeslip game, it's best to tune it for the fuel available conveniently.
Old Nov 15, 2009 | 07:09 PM
  #36
pennetta's Avatar
pennetta
You didn't say much of anything in your post. Nothing works with everything all the time I guess. We are not given much information in many of these threads. The point being made was that your bike needs to be tuned to benefit from higher octane fuel.
Old Nov 15, 2009 | 07:33 PM
  #37
screamin 110
You cant tune in compression! And thats what it takes to use octane.
Old Nov 16, 2009 | 07:39 AM
  #38
pennetta's Avatar
pennetta
Timing, heat, compression and load are some of the variables that could mean that you could utilize a higher octane. And yes, compression is variable and tunable too! My turbo charged car compresses the fuel charge differently at steady RPM than it does under a load and a simple software download can increase compression.
But back to the issue we were all responding to at the begining of this thread; I think you would agree that your engine needs to be tuned to benefit from 100 octane.
Old Nov 16, 2009 | 09:47 AM
  #39
screamin 110
WRONG boost can be tuned. And thats a whole other world. I dont have time nor would I waste my time trying to explain the difference to you. You should do a search about boosted engines.
Old Nov 16, 2009 | 10:03 AM
  #40
pennetta's Avatar
pennetta
If there is more boost, isn't it compressing more fuel mixture into the combustion chamber? BOLD dosn't make you right.
