flat tire
Old Jul 11, 2006 | 08:26 AM
lost6009's Avatar
lost6009
Default flat tire
Has anyone had a problem with the bead separating from the rim? Went for a ride the other day with nothing out of the ordinary happening, went to get gas two days later and the tire is dead flat. I filled it up and there leaks coming out the bead around the valve stem. My bike is a bob, I've never had this problem before without a nail or something on a bike or car. Thanks for any advice
Old Jul 11, 2006 | 09:44 AM
rh8234's Avatar
rh8234
Default RE: flat tire
Tube or tubless tires?
Old Jul 11, 2006 | 12:21 PM
bobcowan's Avatar
bobcowan
Probably the chrome rime cut in to the tube. When yoy get a new tube, be sure and have them check the hole and smooth it out so it doesn't happen again.
Old Jul 11, 2006 | 12:28 PM
sleepneagle's Avatar
sleepneagle
being that it is a bob, you have laced wheels. laced wheels have a band that goes on the wheel first to cover the adjusters for the spokes inside the rim. This separates the tube from the base of the adjusters. In mounting the tire, they could have shifted the liner so the tube chaffes against the adjuster, the tube got pinched in mounting. You ran over something that punctured the tube but did not stay in the tire. There are several possibilities. The tube can be patched or get a new one. check the inside of the tire and placement of the wheel liner before reinstalling.
Old Jul 11, 2006 | 02:19 PM
voyager1's Avatar
voyager1
just my 3 cents worth. i would never patch a tube,they cheap to buy a new one. i ran over a nail 3 days after i got bob. hog towed my bike to dealer. my costs with new tube and labor.. 110.00 !!!!!!!!!!!!!!!!!!!!!! ouch i say.
4MercyMan
Wheels/Tires
May 7, 2019 09:21 AM
fafcpa
Wheels/Tires
Apr 16, 2019 05:15 PM
Gliden
Nov 3, 2012 04:00 PM
grandpatim
Apr 14, 2011 04:30 PM
bobbyd3
May 5, 2008 08:11 PM
