Brake switch
Old Nov 16, 2009 | 03:33 PM
thedonthere's Avatar
thedonthere
Default Brake switch
I just changed handlebars. I did the cardboard trick between the front break lever. I put back together and yep, I have no brake lights now. Funny thing to me is I have no brake lights with the rear foot pedal either. What went wrong and how do I take care of this problem. Kinda stumped.
Old Nov 16, 2009 | 03:35 PM
8541hog's Avatar
8541hog
Don...Both are powered by the same source, perhaps a short that took out the fuse? Both are powered by the OR/WH accessory wire, at least on the 05 Dyna.
Old Nov 16, 2009 | 03:47 PM
thedonthere
Checked, fuses are good.
Old Nov 16, 2009 | 03:55 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Hey Don,
I don't wanna be smart...have you checked the bulb as well?
FXD2003Rider
8541hog's Avatar
8541hog
Do you have a wiring schematic? As I recall they are not wired in series, so one should not affect the other unless the power source is disconnected somehow.
Old Nov 16, 2009 | 03:56 PM
8541hog's Avatar
8541hog
Good point, a short may have blown the lamp instead of the fuse.
Old Nov 16, 2009 | 04:03 PM
2003Springer's Avatar
2003Springer
The brake sw's are normally open switches. either should complete the circuit when pressed. But the problem is probably in the front where you were working. easy to get that little thing out of socket. That is where I would start.
Old Nov 16, 2009 | 04:05 PM
thedonthere
Hey guys after further review, the brake light is stuck on. I pulled the bulb and checked and when the key is on both filaments light up. Really stumped now.
Old Nov 16, 2009 | 04:11 PM
FXD2003Rider
Don,
Must be a short in the handlebar wiring or a stuck brake light micro switch in the r/h housing, I guess. My advise: open up the housing and try to operate the micro switch and see if there is a response from the brake/taillight.
To find parts diagrams see instruction sheet for chrome switch housing kit ...70222-96B (added 09-17-2009) from the database thread
FXD2003Rider
Old Nov 16, 2009 | 04:56 PM
thedonthere
Originally Posted by FXD2003Rider
Don,
FXD2003Rider
Rider, when I open it up and operate the micro switch with my thumb, the brake light AND taillight both turn off. Now what, replace the switch?
