Conversion
Old Jul 11, 2006 | 07:43 PM
Kiel1969's Avatar
Kiel1969
Default Conversion
Has anyone gone wide on their Dyna. I have a 96 FXDL and am looking into going to a 200 rear end. It cost big bicks and was wondering if it is really worth it.
Thanks
Mike
[IMG][/IMG]
Old Jul 12, 2006 | 12:56 AM
bobcowan's Avatar
bobcowan
Default RE: Conversion
Depends on what you mean by worth it. The wider tire looks better to some folks. But it's heavier, and doesn't improve traction or stability.
Old Jul 12, 2006 | 04:41 AM
Z's Avatar
Z
Hmmm.. how could an increase in contact area not result in improved traction?
Old Jul 12, 2006 | 11:21 AM
Mascman's Avatar
Mascman
Maybe he means straight-line traction, where you are riding on the center of the tire, not cornering where you are contacting the sidewall...I'd say you may see a benefit there.
I bought a 2006 Dyna and got a bigger tire with it...I'm sure it would be cheaper for you to do the conversion on the bike you already have!
A 200mm would look pretty sweet IMO.
Old Jul 12, 2006 | 03:08 PM
kimo's Avatar
kimo
The wider your tire the more likely you are too hydroplane.Thinner tires cut thru the water easier. That would be the only negative thing i could see. Im gonna upgrade from 160 mm to 180mm when its time for a tire change. Think you can do that for less than 300 bucks.
Trip58
Sep 2, 2017 07:30 AM
chetter
Apr 25, 2011 05:01 PM
snooper0069
Aug 5, 2010 09:40 PM
creep1
May 15, 2010 07:03 AM
wnogood
Dec 11, 2006 05:52 PM
