Risers.. Poly bushings?
Old Nov 22, 2009 | 06:31 PM
Blackpearlfan's Avatar
Blackpearlfan
Default Risers.. Poly bushings?
Im about to install risers on my fat bob, do I use the stock bushings or the poly bushings...
Old Nov 22, 2009 | 06:39 PM
Blackpearlfan
They are the 6 inch pull back kind from HD..
Old Nov 22, 2009 | 06:40 PM
RCB's Avatar
RCB
Your choice. Poly is the better way to go.
Old Nov 22, 2009 | 07:01 PM
ColoSpgsMark's Avatar
ColoSpgsMark
I tried some poly, but went back the the stock rubber - bars move a bit more, but the vibration is dampened better.
Mark
Old Nov 22, 2009 | 07:37 PM
Topspin's Avatar
Topspin
Mark
Me too!
Old Nov 23, 2009 | 02:52 AM
RKKY's Avatar
RKKY
I put poly bushings on my bikes the first time I remove the bars for any reason. Ran my Street Glide for about 1k miles with the stock set up then switched out the bushings when I went to black bars. Even keeping the stock sized bars I noticed a difference. Not a big difference but definitely an improvement. When I put the 16's on my Dyna I swapped out the bushings and there was a huge improvement.
Old Nov 23, 2009 | 09:32 AM
SC-Longhair's Avatar
SC-Longhair
There's something to be said for bars that will not move when you put some a$$ into it, although with only 6" risers...I'd say you can probably stay with rubber and be fine.
If you were going to high apes, then it's poly. No question about it.
Old Nov 23, 2009 | 12:32 PM
Blackpearlfan
Thanks for the info guys.
Old Nov 23, 2009 | 01:27 PM
JRK5892's Avatar
JRK5892
Polly, NO question!
Old Nov 23, 2009 | 03:47 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Blackpearlfan,
Instruction sheets for the handlebar polyurethane riser bushing kit p/n 56165-03 are in the database........
Please take note of the torque specs: "For all other Models, tighten the two hex head screws to
144-180 in-lbs (16.3-20.3 Nm)".
FXD2003Rider
