clutch adjustment problem
Old Jul 13, 2006 | 04:52 PM
cneyedoc's Avatar
cneyedoc
Stage II
Default clutch adjustment problem
On my 1980 FXE, I suddenly had no clutch as the lever tension went totally loose. I adjusted it at the tranny and it worked for 2 blocks, then the same thing happened again. I adjusted it with the derby cover off, set the cable again, and it worked until I got to the end of my driveway. The tension in the cable goes completely loose. The cable is fine, not stretching. Could this be a problem with my throwout bearing?
rnarus
Jul 8, 2018 10:40 PM
Spider0408
Nov 6, 2017 09:37 AM
GBogard
May 14, 2017 11:46 PM
deez nuts
Apr 23, 2017 10:48 PM
Coastiejosh
Mar 9, 2012 04:44 PM
