Relocation SUCKS
Old Dec 6, 2009 | 05:58 PM
goose246's Avatar
goose246
yep. just looked at it again you're right
Old Dec 6, 2009 | 07:57 PM
bigdaddy33's Avatar
bigdaddy33
Did you check out the license plate bracket on bubbasbrake.com? Wiring is hidden and you can use your directionals.
Can't decide if i love it or hate it so I haven't pulled the trigger. What do you think?
Old Dec 6, 2009 | 08:50 PM
JaronB's Avatar
JaronB
Not sure about that!! I think I have the same feeling. Definitely post some pics when you get it on especially with profile shots. Event though I can't use anything like that because it will cover up the paint job on the rear fender, but still interested in checking it out.
Old Dec 6, 2009 | 09:45 PM
SniperCJ's Avatar
SniperCJ
Originally Posted by rounder
you know the cleanest way to do this is to get a kuryakin panacea taillight.
True, but for some reason I like the looks of the turn signals. Not a fan of the Panacea.
Old Dec 6, 2009 | 11:11 PM
pitbull1's Avatar
pitbull1
Default signal relocate
My saddlebag support used the existing signal mount so what I did was just redrilled the 2 holes for the signals about a inch from the end on the same support bar it was originally mounted on.Looks just like it did from the factory..Just gotta use a sharp punch to strike and dimple the chrome so the drill bit dosen't walk on you..It's a 3/8 hole and I drilled it in increments.First hole 1/16 then 1/8,1/4 then the final 3/8 hole.
Old Dec 9, 2009 | 10:09 AM
SC-Longhair's Avatar
SC-Longhair
Originally Posted by JaronB
Oh yea I got the detachable hardware there also, just waiting on some button head bolts to look better. And the reason it won't fit on a Dyna fender is the Deluxe, SG, etc have indents on their fender for the mounting points. Since the Dyna doesn't it doesn sit flush and you'll have a weird gap at the bolts, which is why you grind down the light bar a bit. I used a bench grinder.
I don't know if you have a Fastenal near you but they have chrome button heads in stock. It's a great store.
http://www.fastenal.com/web/home.ex
Old Dec 9, 2009 | 10:11 AM
SC-Longhair
Also, I've seen the Street glide light bar on a Street Bob. Looks good in person.
Or get jiggy and relocate the signals down to the ends of the swingarm.
Old Dec 9, 2009 | 10:47 AM
07bobber's Avatar
07bobber
I hated my rear signals also so i just took them off..
Old Dec 9, 2009 | 08:04 PM
JaronB's Avatar
JaronB
Yea I already went there. They wanted 25 bucks for 5 bolts and I only need two. That's the last resort but a buddy is going to hook me up cause he's got two from when he had the detachables. If that doesn't work out I'll drop the cash!! Thanks!!
Old Dec 9, 2009 | 08:32 PM
SC-Longhair
Those prices seem a little out of whack because I was going to order 4 chrome buttonheads for the handlebar clamp and total cost would have been $3.50 from fastenal.
