Rear Pulleys?
Old Dec 6, 2009 | 12:56 AM
paul s's Avatar
paul s
Default Rear Pulleys?
I need to get rid of that 66T rear "07/08's", is there any 68T's from the newer bikes out there to be had?
Old Dec 6, 2009 | 08:35 AM
mud's Avatar
mud
The 06 International sprocket is 68 tooth............
The 06 Domestic sprocket is 70 tooth............
Old Dec 6, 2009 | 12:39 PM
rounder's Avatar
rounder
a 70 tooth rear will almost equate to a 30 tooth front for your gearing I believe.
Old Dec 6, 2009 | 02:49 PM
paul s's Avatar
paul s
I have the 30T already and a 68T would fit without a belt change but I'm not so sure about the 70T it would be close. I remember somebody with an 09 going from 32/68 to 30/70, I was thinking there might be a few 68T pulleys around but I cant find any yet.
Old Dec 6, 2009 | 03:44 PM
mud's Avatar
mud
did you check posting # 2 ??
Old Dec 6, 2009 | 04:33 PM
grbrown's Avatar
grbrown
A change of 2 teeth on the rear pulley is hardly noticeable or worthwhile. What do you want to achieve with making a change? I replaced my 03's 25T crank sprocket for a 21T. Now THAT was a change worth making!
Old Dec 6, 2009 | 04:53 PM
Lama's Avatar
Lama
2006 pulleys are wrong belt-width size for 2007+.
Old Dec 6, 2009 | 05:12 PM
mud's Avatar
mud
Didn't know the 07 up went to a wider belt.
What's the advantage to the wider belt??
Old Dec 6, 2009 | 05:33 PM
thedonthere's Avatar
thedonthere
07s have a 1" belt, 06s were 1.125. I have an 07 belt and pulley on my 06.
Old Dec 6, 2009 | 06:26 PM
rounder's Avatar
rounder
I doubt you would notice much at all with just 2 teeth in the rear. Certainly not worth the money of a sprocket anyways.
