Rotor Question
Old Dec 14, 2009 | 09:34 PM
drfalken's Avatar
drfalken
Default Rotor Question
Not understanding something. I was going to upgrade my brake rotors this winter to something a little better looking than stock. I figured any 11.5" rotor would do BUT looking in the harley accessory book i noticed that only 1 or 2 sets were listed as fitting my 06 street bob. So what makes them different. Frankly I wasn't going with a moco part at all but now I am a little leery about dropping a couple hundred on something that wont fit. Can i get any rotor or do i need to take something else into account.
Thanks in advance for the info.
Old Dec 14, 2009 | 11:59 PM
FXDCme's Avatar
FXDCme
Default rotors
There is a difference. It will depend on the rims you have too. If you have the spoke stock rims, they have a floating rotor. These are common and have a partician between the mount system and the actual rotor. The other set-up has a one piece front rotor that are mainly on aftermarket rims. These have a different mount that is wider apart since it is furture from the center hub.
Old Dec 15, 2009 | 12:43 AM
FastHarley's Avatar
FastHarley
Former Sponsor
Your 2006 rotor is 300 mm and not 11 1/2".
Old Dec 15, 2009 | 01:06 AM
FastHarley's Avatar
FastHarley
Former Sponsor
Jay Risks motorcycle which is a 2006 and has 300 mm rotors on them.
Old Dec 15, 2009 | 07:33 PM
drfalken's Avatar
drfalken
any good sources for replacements besides the moco?
Old Dec 15, 2009 | 07:41 PM
jarhead45's Avatar
jarhead45
check with howard up above... he can set you up I am sure. Or just be brave and go dual disk.
Old Dec 15, 2009 | 07:45 PM
Phrogman's Avatar
Phrogman
You can hit J&P online to get an idea. They let you input your bike model to narrow your results.
You should see a lot of 11.8" and/or 300mm rotors resulting from your search. 300mm=11.76" so they are basically the same, just reported differently.
Old Dec 16, 2009 | 04:05 AM
mikeurig's Avatar
mikeurig
Search the web for 11.8" rotors. Arlen Ness makes them, PM makes them but mostly for their own wheels. Don't like the stock rotors?
http://www.dragspecialties.com/fatbo...0rotors&page=1
Old Dec 16, 2009 | 11:20 AM
FastHarley's Avatar
FastHarley
Former Sponsor
Default Mmc
I can do full racing rotors in 300 mm (the size you are asking about) in MMC or AKA Metal Matrix which weighs in at about 2 pounds each. You would always have to use an Organic pad such as a Lyndall (Red), EBS, Frodo Platimum, et al for $309.00 each plus actual shipping. These are lifetime guaranteed and look something like these but a little smaller and not in chrome.
Old Dec 22, 2009 | 10:08 AM
bugguy357's Avatar
bugguy357
I need a set of front rotors and pads for my 08 FLHX.
gid58
Nov 14, 2017 04:37 PM
619DYNA619
Sep 15, 2016 06:39 PM
Lu
Mar 22, 2015 12:54 PM
harley50
Aug 5, 2009 06:11 PM
phat96
Jul 29, 2008 07:18 AM
