andrews 54h cam install
Old Dec 22, 2009 | 01:35 PM
Lama's Avatar
Lama
http://cgi.ebay.com/ebaymotors/FEULI...item1c0a20ac31
Old Dec 22, 2009 | 01:44 PM
lhcstreetbob's Avatar
lhcstreetbob
thanks lama i found one at a dealership ill have it tommorow ill just start over i guess ...the best advice i have for anybody wanting to there own cams is practice on somebody elses bike lol.....
Old Dec 22, 2009 | 04:04 PM
Ratbob's Avatar
Ratbob
Fantastic advice lhc, can I borrow your bike?
That really blows, especially since you were following the shop manual. It's great for some things, but I find (at least for '08) that it is full of contradictions, and missing a lot of key info.
Hope the oil pump is the full extent of the damage, and good luck with the new cam!
Old Dec 22, 2009 | 05:01 PM
lhcstreetbob
hey thanks i hope its an easy fix with just the oil pump i didnt see any metal in the oil and the oil pump really isnt that chewed up i guess scored would be a better way to say it
Old Dec 22, 2009 | 05:19 PM
Lama's Avatar
Lama
When you install the new oil pump, make sure you put a NEW o-ring with some grease where the oil pump inserts into the cam chest. IMPORTANT.
Make sure you do the engine rotation and 4-bolt torque sequence when tightening the 4 oil pump bolts.
If you get a chance, do a pinion runout check. You should have the time, and you really DO want to know your pinion runout.
When you get the bike back together, buy some cheap 50 weight oil and a cheap black oil filter, or a crappy FRAM oil filter.
Fill bike with the cheap oil, new filter, start bike and immediately shut it off. Start again, shut off.
Do this twice to get oil flowing without overly running the engine.
On the third start, run it for a few minutes, listen to it. Make adjustments as needed.
Get it really hot.
Drain oil and remove filter.
Install NEW oil and NEW filter, good oil.
You should be good after that.
Old Dec 22, 2009 | 05:24 PM
lhcstreetbob
thanks again lama im not surehow to do the pinion runout test? and could you elaborate on the tourqing the bolts while spinning the tire? dont want to f anything up again....thanks
Old Dec 22, 2009 | 05:46 PM
Lama's Avatar
Lama
Pinion runout:
http://www.youtube.com/watch?v=8_ABdzSrge0
Cam change/oil pump:
http://feulingparts.com/pdf/7000.pdf
https://www.hdforums.com.au/Default....263&view=topic
Old Dec 22, 2009 | 06:30 PM
lhcstreetbob
lama you are the man !!!! where do you live im buying beers.....
Old Dec 22, 2009 | 07:34 PM
nathanw's Avatar
nathanw
Lama, please explain that video for people that have no clue ( like me ). Is this a manufacturing defect or improper installation? What will the .005 runout cause?
Old Dec 22, 2009 | 10:10 PM
chad peterson's Avatar
chad peterson
Always should check runout...this has become more of an issue for the 06 & up dynas, but has been a potential issue in the past aswell! Must check runout if going to gear driven cams...the chain is more forgiving to more runout, gears are not!
Lama has put out some really good info on this thread...all spot on! This is why I dig these forums...good information for the most part! Although I'm a big fan of adjustable pushrods, prolly cause I change sh** so much! LOL!
