Neutral light question
Old Dec 31, 2009 | 03:05 PM
rounder's Avatar
rounder
Default Neutral light question
looking to replace my idiot lights with led's. just gonna have neutral and turn signal lights. Here's the question. LED's have a wire for the source(+) and neg wire. On my bike the stock neutral light has the neutral wire(tan) and the other wire is orange which is then Teed to the oil light and into the speedo and connector. Orange is the power wire. Will an led work? Do I wire the led to a tan wire and orange wire with no ground?
Old Dec 31, 2009 | 03:18 PM
JRK5892's Avatar
JRK5892
when i did Mikes i just tested the LED on the wire, ti only worked one way so i cut and soldered it... works great
Old Dec 31, 2009 | 03:50 PM
super05's Avatar
super05
The turns and beam always have the low side grounded, and illuminate when they get +12V, constant for the beam, pulsed for the turns.
The N and Oil Pressure light work opposite, they always have +12V on the high side, and the lamp comes on when the switch closes to ground on the low side, otherwise there is no current flow thru the lamp and it will not illuminate.
So yes - as JRK say - it's only going to work one way, orange wire to the high side of both leds, other respective wires to the low side.
Make sure u use LEDS made for 12V applications. They have a built in resistor. you can still use raw leds, but you will need to wire a resistor in series - otherwise - pop!
Old Dec 31, 2009 | 05:53 PM
rounder's Avatar
rounder
yeah ok I get it. orange to the positive, other color to it's negative. I am using 12v leds with built in resistor.
RapidRoy99
Electrical/Lighting/Alarm
18
Dec 16, 2018 02:34 PM
TankWilliamsJr
Aug 24, 2016 08:14 PM
iron883dreamer
Feb 21, 2016 09:04 PM
booch
Mar 11, 2013 05:29 PM
DickGrayson
Apr 25, 2007 11:52 PM
