I'm just messin with ya, well kinda. You might try doing a search on this subject. If I remember correctly there has been some advise given in the past.
Good Luck.
from what i am told,it is a pretty big job,even if you are a good wrench. one reason i went with forward pegs. i really like being able to go back and forth :
You can install them without taking the primary off. I put them on and wired the inside shifter arm to the engine so it wouldn't bang against anything. I will finish the job this winter when I can take my time and really do a good job and not screw anything up. (fingers crossed)
I just installed the 06 Forwards on my Street Bob last night withthout removing the primary, as so many other folks have done. The only issue I ran into was me being stupid (see my post today!) and breaking the head off a bolt. Otherwise, a clean and satisfactory job.
He just left the shifter shaft in. The only way to remove the shaft without cutting it is to take the inner primary off.
I did mine and I am hardly a good mechanic. I got the service manual made a tool or two and took my time.
Took 4.5 hours total.
