Need some clutch help
Old Jan 18, 2010 | 12:30 PM
FUQUA's Avatar
FUQUA
I've done the same install before and had the same problem. Fire it up shift and it will fall into place.
Old Jan 18, 2010 | 12:33 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Originally Posted by thomaskray
Ok. Thanks all. I just wanted to make sure I wasn't missing something.
Sounds like my problem is normal and not really a problem at all.
Anxious to hear the result, Thomas!
FXD2003Rider
Old Jan 18, 2010 | 01:53 PM
cornishman's Avatar
cornishman
I just put on some 16" apes, new hand controls, and a new Barnett clutch cable. I followed my Clymer manual to the letter in removing the side plate behind the exhaust, removing that clamp ring, the roller bearings are in their groves, the opening of that clip ring is positioned according to spec, etc, etc...
Then removed that derby cover on the primary side, adjusting the locknut and pushrod according to spec. I then made my inline cable adjustments on the cable making sure I had 1/16" of play. Filled the trans with 22 oz. of fluid.
The clutch lever action "feels" good at a standstill. Smooth tension, no binding, and it seems to be working right.
Here's the problem: Without starting the bike, If I put it in first gear with the clutch pulled, I can't roll the bike. It doesn't feel like the clutch is fully disengaging. I try to adjust it one way it is too "tight" and the lever will not pull in all the way, I adjust the other way, and it feels like there is too much slack in the cable.
I've taken everything bake apart, reinstalled it all again according to the manual and according to a few how-to videos on youtube.
It still can't roll it in gear with the clutch pulled.
Am I missing something here? I'm afraid to start it and try shifting since I don't wanna damage my trans.
Any guidance, experience, or thoughts would be much appreciated.
Mine was the same and it caused some head scratching as i double checked everything. I checked on the forum ( it was about eighteen months ago) and the general consensus was that all was ok. So i just carried on and all is well, it still "drags" in 1st gear when not running with the clutch in, but no issues. Must be one of "those" things.
Old Jan 18, 2010 | 06:41 PM
PigInaBlanket's Avatar
PigInaBlanket
Yep the first time I adjusted my clutch I noticed if I had it in gear with the clutch pulled in that it wouldn't roll easy and if I tried to start it in gear with the clutch pulled it would lurch forward. I sat there for hours playing with the clutch adjustment until I finally found out this was normal for the bike. I felt like a fool haha
Old Jan 18, 2010 | 08:20 PM
jss1975snow's Avatar
jss1975snow
Man, I love your Avatar!
Old Jan 19, 2010 | 05:44 AM
thomaskray's Avatar
thomaskray
Thanks. There's nothing like a good ***.
Old Jan 27, 2010 | 03:14 PM
thomaskray's Avatar
thomaskray
FXD2003Rider
Yep. Everything is cool. The first start, when I put it in gear, had a good loud "clunk" and a little lurch. But then as everyone said, it all fell into place.
Shifting smooth. Thanks all. Now I just gotta post some new pics with the apes.
Old Jan 27, 2010 | 03:44 PM
FXD2003Rider
That's good news, Thomas! Thanks for letting us know...can't wait to see the pics.
FXD2003Rider
Old Jan 27, 2010 | 03:58 PM
JRK5892's Avatar
JRK5892
i can do nothing but look at the avitar... and smile
Old Jan 27, 2010 | 05:18 PM
PigInaBlanket
I could do more but my fingers are blistered and my wrsit is sore...
