Just installed a quick release HD compact windshield
Old Jan 19, 2010 | 06:39 AM
rdown1976's Avatar
rdown1976
Default Just installed a quick release HD compact windshield
Wow, that was easy to do. The WS is a little higher than I thought it would be at 18". It comes to about my nose level when I am sitting on my Bob. I think I would like it about 1-2" shorter so I can see over it better, but I will see if I get use to it.
One thing if you buy one, make sure it is a new WS that was not restocked by HArley. My shield looked perfect, but after I installed it I noticed 1-2 little surface scratches on the shield. Doubt HD will fix it since I installed, but I did not cause it....
Thanks
Old Jan 19, 2010 | 08:47 AM
SuperglideKen's Avatar
SuperglideKen
There is a few inch's to move it up or down. I like mine all the way down so I can see just over the shield. I like a sheild so much now I went and bought one for my ATV. It was much more of a pain to install than the HD.
Old Jan 19, 2010 | 09:15 AM
jerseyjeff62's Avatar
jerseyjeff62
Old Jan 19, 2010 | 04:14 PM
ZChan's Avatar
ZChan
Even the new ones in sealed boxes may have scuffs. Mine did. Dealer noticed it as they installed it with several other parts I had ordered when bike was new. They let me use it until the replacement came in. I don't use it too much though. Kinda nice in bad rain and stuff.
Old Jan 19, 2010 | 04:34 PM
Taddeoeg's Avatar
Taddeoeg
I got a used one off eBay and it looks nearly perfect. Even all the way down on the forks I find it a bit tall as well - fine sitting in the garage but when I get out on the road and slump down the top of the shield cuts my field of vision.
Plan to chop off 1" and see how I like that. If not I'll go 2".
Old Jan 19, 2010 | 04:49 PM
Mascman's Avatar
Mascman
I have a QD and instead of chopping from the top, I cut it above the light to drop it down.
Most of the updraft comes from below the shiled, so I figured it would help with that.
I also installed some Road King deflectors on it so everything comes off in one piece.
And 2 minutes later...
Old Jan 19, 2010 | 05:43 PM
BlockHead96's Avatar
BlockHead96
Thanks
That's exactly where it should be for the best possible coverage! You can lower it down till it almost hits the headlight housing.
Old Jan 19, 2010 | 05:44 PM
BlockHead96
Where did you find those lowers?????????
Old Jan 19, 2010 | 06:20 PM
rdown1976's Avatar
rdown1976
How do you chop it off 2"? What tool do you use?
Old Jan 19, 2010 | 06:22 PM
rdown1976's Avatar
rdown1976
Does anything take the scuffs off a WS?
